HandyCruiser
- Jun 28, 2021
This weekend, me and my sweetie went on our first proper road trip in our new 2021 Ram 1500 Laramie 4WD. Before this, our longest trip had been the drive back to Central Arkansas from near St. Louis where we bought the truck. This time we did the following:
First thought, the Laramie is an excellent road trip vehicle. Lots of room and plenty of power to take control of the open road. It has a look like no other truck and people do turn their heads to see it. The BAKflip F1 hard tonneau cover and Bed Mat, along with the factory lighting from the Bed Utility Group, make the world's best trunk for all your stuff. The automatic wipers and high beams make driving easier. The factory stance of the 4WD Laramie is perfect for worry free driving over relatively rough terrain without getting the chrome scratched or dirty. And the open panoramic roof is awesome in the evening after the southern sun gets low enough not to be on the "Broil" setting. AC worked great. No complaints on staying cool in mid-90's humid weather while cruising old southern houses gussied up like French prostitutes for a TV show.
That said, here is what our truck may be lacking:
- We started going southwest from Central Arkansas down I-30 to Texarkana, TX for lunch.
- Then south down I-49 to Shreveport, LA to I-20.
- East on I-20 across northern Louisiana to Vicksburg, MS. for the night.
- The next day, we stayed on I-20 to Jackson, MS.
- At Jackson, we took US 49 down to Collins, MS.
- Then we took US 84 into Laurel, MS where that hometown home improvement TV show is made.
- Got there, did that, and bought the T-shirt (literally).
- Backtracked to Jackson on US 49.
- Then stayed north on US 49 through Yazoo City, MS all the way to the Helena bridge (Where part of the "In The Heat of the Night" movie was filmed).
- Once we crossed that two-lane bridge back into Arkansas, we stayed on US 49 to Brinkley, AR.
- We then got on I-30 and came back to Central Arkansas.
- The factory Bridgestone Dueler Tires cry like babies every time the pavement is not smooth. Like the factory Firestone Fire Hawks on the muscle cars, these will need to be changed out soon.
- Mississippi uses a lot of pea gravel in their asphalt pavement. When worn (as most secondary Mississippi roads are), they deaminate and can even become washboarded. Our Laramie does NOT like these worn out pea gravel asphalt roads. The truck bounces and squeak even at low speeds. I am thinking the truck needs better sway bars.
- There is a low rubbing sound that can be heard even when crawling along over rough pavement. I folded up the hard tonneau cover to make sure it wasn't that. No change. It may just be the rubber bushings in the suspension, which is still factory fresh. I'm hoping it goes away with time.
- Damaged pavement on highways is dangerous at high speeds. At 78 mph on I-30 in a slight curve, I crossed a patch of repaired pavement and the truck almost bounced off the road. Again, I'm thinking the sway bars are too weak.
- Auto high beams go to high while passing semi trucks on the highway. I had several big truck drivers flash their high beams at me after passing them at night on the Interstate. I first thought the drivers were mistaken due to how bright the factory LED headlights are. But then I noticed the auto high beams switching to high when I passed trucks and there was nothing on-coming on the other side. It was only for a couple of seconds, but it's enough to blind a truck driver through his or her side mirror. I will have to remember to turn the auto high beams off when on four-lane roads.
