Vinnie.
"the tune gave you so much torque it twisted the cab frame and forced a leak in the window seal"So you’re telling me my tuner will keep me from getting my rear window replaced under warranty![]()
bahahahah
If memory serves me correct, pulling ABS fuse “should”. Don’t quote me on that though.I got awhile before my wife lets me tune this truck, but until then, is there anyway to turn off the stability control, even what fuse I could pull?
Ge a TazerDT and you can fully disable ESP and TSCI got awhile before my wife lets me tune this truck, but until then, is there anyway to turn off the stability control, even what fuse I could pull?
It wasn’t listed, so if you’re sure, I’ll be looking at it for sure. I’ll probably message tazer to be sure. Unmarrying for a trip to dealer sounds good also.Ge a TazerDT and you can fully disable ESP and TSC
Have had a TazerDT, and it definitely does. Is even listed as one of the features. Or at least was. Hold down the traction control button for 10 seconds to fully disable. You have to turn truck off and back on again to reset.It wasn’t listed, so if you’re sure, I’ll be looking at it for sure. I’ll probably message tazer to be sure. Unmarrying for a trip to dealer sounds good also.
That's why you need a buddy at the dealership, or buy enough vehicles that they don't care, or BOTH!Once a warranty is void the dealer wants nothing you do with you regardless of what it is. Unless you pay out of pocket that is.
You can sell the pedal commander and tune the pedal to what you want. Hemifever, Jay Greene, and Flying Ryan are popular. Find other threads that deal with each’s pros and cons.Just ordered the DiabloSport Trinity 2 w/ unlocked PCM and wanted some guidance on those who have used it. I understand it comes with its own tunes to choose from but what do you guys recommend as far as a third party engine and transmission tune? Is the transmission tunable with that kit alone or is any other hardware necessary? Also, I have the pedal commander now, do I remove and sell it or keep it with this kit? Thanks in advance!
There is also Johan at [email protected]. I have not used him yet but email exchanges have make sense.You can sell the pedal commander and tune the pedal to what you want. Hemifever, Jay Greene, and Flying Ryan are popular. Find other threads that deal with each’s pros and cons.
I personally got the tuner for a little more oumf out of the truck since I tow a 32’ CC and I’m lifted pushing 35’s. I just have the drop in K&N and the AWE exhaust in terms of “performance” but my truck came with 4.10 gears which helps for my towing. Hoping for better shifting as well.
I stand corrected, I just double checked my build sheet and you’re right. 3.92 gearing.If it's a 5th Gen 1500, it did not come with 4.10 gears.
What year is your truck?Just ordered the DiabloSport Trinity 2 w/ unlocked PCM and wanted some guidance on those who have used it. I understand it comes with its own tunes to choose from but what do you guys recommend as far as a third party engine and transmission tune? Is the transmission tunable with that kit alone or is any other hardware necessary? Also, I have the pedal commander now, do I remove and sell it or keep it with this kit? Thanks in advance!
2019 5.7 e-torque 4x4 and 8-spdWhat year is your truck?
Very nice! You're going to love it!2019 5.7 e-torque 4x4 and 8-spd
It's either the 91 or 93 octane fuel tune I forget which, but yes it's the most aggressive tune.I’m assuming the “Diablo Tune” is the best preloaded one? Chose that one, 20% throttle boost, MDS off and Disabled Auto On/Off. any further tweaks anyone would recommend? Thanks in advance.
