Nice trip. What are you doing with the old pine wood?
He’s testing the factor of safety on the published payload capacity!Nice trip. What are you doing with the old pine wood?
Where did you order those from and how muchPut in the Mopar utility rails, the 16 rivnuts were a pain, but the rest was easy. View attachment 102175View attachment 102177View attachment 102178
There is a drain kit a hose and a plastic piece that snaps on the Val and the hose go’s on and no mess. I put the hose in my drain jug it is greatDid my first oil change since installing my fumoto valve that is supposed to make oil changes easier and less mess. I might have to get a different drain pan because as soon as the oil hit the drain pan, it started splattering everywhere, all over my head and faces almost a 2' radius around the pan. So actually made more of a mess with the oil than just letting it hit sway bar. Finally got the pan centered with the stream so it was hitting the hole in middle and it stopped splattering. Thinking a screen on top or something to reduce splatter, or will have to get a hose that fits over the nipple on valve so it goes straight into drain pan. It just doesn't "flow" out of the valve smooth enough. Waiting on engine to cool down a little more before taking filter off as I use the larger older Hemi filter so take a little more to get it out
Yeah, saw that when I ordered the valve. If I would have known it was going to splatter like it did, would have bought it with valve. Tried putting a hose on, but didn't have one I garage that fit over the nipple and would stay on.There is a drain kit a hose and a plastic piece that snaps on the Val and the hose go’s on and no mess. I put the hose in my drain jug it is great
No video, but this was aftermathOmg
, please tell me you have a video!?!
Hoping he wasn't gumming up his chimney with that old soft pitch wood. Testing payload is about what it's good for.He’s testing the factor of safety on the published payload capacity!
 www.bamwholesaleparts.com
				Did this last week myself. Great Mod.Added Datin underseat storage to my 2021 1500 crew cab. Tonneau cover and bedrug next week or so.
You have to download aaad thru a websiteI'm listening....
You may want to check if the light hits your tailgate, it has happen to several guys in the past. I trimmed my license plate a bit on the bottom so it could sit lower and avoid hitting the tailgate when it's down.You need one of these. 1800 Lumins. Here’s a link:
View attachment 102034View attachment 102035View attachment 102036
All chrome parts will be for saleRemoved and replaced all chrome pieces around the window, R/R all emblems except grille with black, R/R door handles with black. Removed and power coated Rims and tow hooks. Replaced chrome exhaust tips with black chrome tips. On Monday I take to shop to R/R chrome front and rear bumper, grill and a sport‘s hood that will be color matched to the truck. All oem parts with no plastic dip or vinyl wrap.
Once done I will post the completed updated look.
I saw this option. I hate that you aren't able to use offroad 1 or offroad 2 with these installed. I saw that one of the "Ram Gurus" has been running the Daystar leveling kit. This kit allows you to run all levels of your Air Suspension. https://www.revelperformance.com/lifts/2019-ram-1500-daystar-adjustable-air-sensor-links/I believe this is the one they are putting on for me..
2 Inch Leveling Kit | Air Ride | Ram 1500 4WD (2019-2025)
Level your RAM 1500 with 4-Corner Air-Suspension using Rough Country’s 2-inch kit. Gain ground clearance, a bold stance, and retain factory ride quality.www.roughcountry.com
I’m interested in the chrome brow upper part of the grilleAll chrome parts will be for sale
Super nice truck and super nice scenery!!!!
