Cr250Ram
- Jul 21, 2019
Truck 2019 Ram 1500 5.7 3.21 CCSB
Steer axle: 3900
Drive axel: 4100
GVWR: 7,100
GCWR: 13,900
Trailer 2020 Springdale 260TBWE
GVWR: 7,525
Advertised hitch: 525
Water full is 500 (451 trailer 50 hitch)
I have a WD hitch
I went by Cat scales after picking up trailer. Trailer was dry with full propane and batteries and WDH. I got the following readings (with me in truck);
Steer axle: 3420
Drive axel: 3160
(Veh weight: 6580)
Trailer axle: 5150
Gross: 11,720
Base on Ram specs I have the following weight left over that can be added;
Steer axle: 480
Drive axle: 940
(Veh weight: 520)
(Combo weight: 2,180)
(Trailer weight: 3,080)
I estimate I will add 1,000 pounds of gear/food/etc to my trailer. I estimate the following will be added to my GVW; my family will be 350 added, 50 to hitch from trailer water and 120 from gear added to trailer (@.102% as calculated dry). This would put my GVW right at 7,100 which is in spec. Obviously I will be pushing the truck to it’s max but we are only weekend warriors going hopefully 5-10 times a year to places within a few hour drive. Any thoughts? Obviously for comfort I would upgrade truck but I would prefer not to.
estimated final specs:
Steer axle: 3595
Drive axel: 3505
GVW: 7,100
GCW: 13,521
anyone have any suggestions or advice? Anyone tow to max levels like this?
Steer axle: 3900
Drive axel: 4100
GVWR: 7,100
GCWR: 13,900
GVWR: 7,525
I have a WD hitch
Steer axle: 3420
Drive axel: 3160
(Veh weight: 6580)
Trailer axle: 5150
Gross: 11,720
Steer axle: 480
Drive axle: 940
(Veh weight: 520)
Steer axle: 3595
Drive axel: 3505
GVW: 7,100
GCW: 13,521
