2021 Limited the signal nightmare!!
Thundersnow
I have a 2021 Ram 1500 limited with less than 5k on the od. A week ago I got a message that my front left turn signal is out. I got out and checked and all turn signals are working just fine. The left mirror light signal as well as the interior turn annunciation are both blinking rapidly. The dealer found a small cut in the side marker light wire of the left headlight wiring harness. They had a ram engineer come in to offer assistance on the repair. After fixing the wire and doing a hard reset via batter disconnect the problem went away for about a minute of signaling and then came back with the message and fast blinking. Now I’m being told that the whole BCM needs replacing. In any case I’m wondering if anyone has had a similar issue. There is a STAR case pending for my vehicle if any Ram reps are reading this I’d be happy to communicate.
Thanks for reading
Thanks for reading
The site isn't ran by Ram, but @RamCares might be able to help
Well the whole point was to see if someone had a similar example. If @RamCares is lurking and willing to respond I’m listening.
My truck had a weird thing happen with the turn signal early on and has not done it in 30000kms. The first weekend I had the truck I was driving down the highway and signaled to change lanes. My left turn blinker stayed on. It was on in the left position and in the neutral position, would go off when in right turn position. I could no longer signal for right hand turns. It took 5 or 6 engine cycles for the problem to correct itself. 17000kms later it did it again, but was gone after one engine cycle. It has not happened since
Sent from my SM-N986W using Tapatalk
Bizarre behavior!
My left hand turn signal doesn’t go back to neutral after turning left about 60% of the time. I have to manually flip it back….not worth having them techs touch it though.
