Anyone? I can't seem to find the post anywhere where someone activated their lights with Alpha OBD.What are the AlphaOBD instructions for activating these lights instead of having the dealer flash them?
Did you figure this out? I just completed this project tonight and was able to turn them on using AlfaObdAnyone? I can't seem to find the post anywhere where someone activated their lights with Alpha OBD.
Hi, can you answer this question,Did you figure this out? I just completed this project tonight and was able to turn them on using AlfaObd
see post #9Maybe a terrible place to ask, but does anyone know where I can get the covers that go where the bed light would insert? Or for anyone that installed the lights and no longer need the covers wiling to share?
I've got a slightly different idea in the works, but the dealer sprayed the bedliner over the old covers so I literally have to cut them out...
you don't need ALPhA OBD:Anyone? I can't seem to find the post anywhere where someone activated their lights with Alpha OBD.
Thanks for doing this work.Alright now a question for the parts guru out there. After researching cost it looks like it is about $40 each to purchase new Jumper Chassis Connectors
I want to verify that these are the correct harnesses for a 5.7 bed, Rambox (XB9), and now Cargo Lights(LPL)
Right,[LPL], [XB9] 68359103AD
Left,[LPL], [XB9] 68359432AD
*With the AC version being superseded*
Next question - Anyone that wants to build me a harness from the Cargo lights to the Jumper Harness connection (XY801 and XY802), as it seems I can not order them.
I can provide the inline diagrams if needed.
The Critic, that is true.Thanks for doing this work.
Based on my limited research, I think we need these two harnesses:
68440590AA
68438673AA
It appears that FCA makes harnesses for no LPL or XB9, LPL only, XB9 only, and LPL + XB9.
2020 RAM 1500 Big Horn Crew Cab 5.7L Hemi V8 Wiring, Chassis and Underbody.
Diagram of OEM Wiring, Chassis and Underbody. Contains 23 parts priced between $4.64 and $226.24. Fits 2020 RAM 1500 Big Horn Crew Cab 5.7L Hemi V8.www.moparpartsoverstock.com
If I understood your research correctly, with the correct jumper harnesses, the bed lights should be plug and play (without having to run a dedicated circuit) and we would just need to do a vehicle configuration restore using WiTech (after the sales code gets added). The bed light assemblies I see (when ordering individually, not the kit) already include a harness:
Lamps, Truck Bed.
Diagram of OEM Lamps, Truck Bed. Contains Lamp. Liftgate. Left. [pick-up box lighting] for Lamps, Truck Bed. Fits 1500.www.moparpartsoverstock.com
Glad to hear. I have two additional questions:The Critic, that is true.
If you order the individual bed lights they do include the harness.
I ordered the wiring harnesses and installed. The new harnesses come with all the tabs, so I just cut them to make it quick.
Had to drop the spare to help with the one that runs across.
Overall was super easy!!
I have a reprogramming, so no need to go to dealer.
No new grounds. Use the same the original harness uses, the two "pigtail" harnesses come prepped with the grounding connector.Glad to hear. I have two additional questions:
1) Did you have to run any new grounds?
2) Can you confirm the part number of the harnesses that you used?
Thank you
68312566AB | Lift-Gate Lamp, Right |
68312567AB | Lift-Gate Lamp, Left |
68359432AD | Jumper Wiring, Left | |
68359103AD | Jumper Wiring, Right |
Thanks! It looks like the jumper harnesses for the 2019 models use a different part number than the 2020's. Not sure why.No new grounds. Use the same the original harness uses, the two "pigtail" harnesses come prepped with the grounding connector.
So I went from XB9 to XB9+LPL
Parts for my configuration (ram box + bed lights)
68312566AB Lift-Gate Lamp, Right
68312567AB Lift-Gate Lamp, Left
68359432AD Jumper Wiring, Left
68359103AD Jumper Wiring, Right
Sorry for the delayed response.
