The Raptor Has A Cool Aux Switch Bank - So Can The RAM!
  • Thread starter Thread starter sbourne
  • Start date Start date
got mines great product just dont drop it
I just ordered these 12 Conductor Connectors to use in my Install:
Malodave
Fresh Print of my Switch Panel with PSI Display:
Switch Panel Wiring:
Red Fused Battery Wire goes to the Power Switch for the BED. So it works with out the truck being on for camping.
Orange ACC 12V power to the rest of the Switches, the constant LEDs, and the PSI Guage.
Black Ground Wire goes to two connections on each Switch and to the PSI Guage.
The Red/Black/Green wires go to the Pressure Sensor
Gray Wire goes to the AUX Fuel Xfer Pump
Green Wire Goes to the Front LED Driving Lights Relay
White wire goes to the Reverse LED Pod Lights/Relay
Yellow Wire Goes to the Bed/Cap Relay
Blue Wire goes to the Air Compressor Relay
Violet Wire goes to the Air Horn Selenoid
Mounted in Overhead Console on Desk:
Mounted in Truck:
The Power Switch to the Bed/Cap I still need to order in the Contura III
square type. I still want to paint it with a light coat of Black. Then I just have to
do all the rest of the wiring runs.
Malodave
@Malodave Love it. Looks great. Sanded mine down till baby smooth with 500, 1200, then 1500 wet sand. Sprayed with 2 coats filler primer and sanded again with 500. Then 2 coats satin black and 2 coats matte clear. Looks just like factory. Got a socket flat head bolt in black oxide finish. Switches from Otrattw site. Interior lights, bed lights, light bars, rock lights, wheel well lights, and grille lights. Can’t wait to get wiring done. Thank you again for your awesome work sir!
I wonder if the few Members that asked for the 3D Files
will come back and Post with their Prints and installs?
Malodave
I am selling for $50 including shipping.
Send me PM with your Shipping Address and I will give you my PayPal.
I clean up the supports. The rest of the finishing, Fitting Switches, fine tune
the install in Console, light sanding and Painting is up to you.
Malodave
Malodave
Sorry I’m new to all this. Did you run wires to all those switches? Is there a wireless option?
Yes, Everything is wired. If you can find a wireless solution, you can try to use it.
Again, I am only supplying the 3D printed Panel. Everything else is up to you.
Malodave
Wow that looks amazing! im going to try and duplicate your amazing work when I get my switches in. Two quick questions... what are the dimentions for that little hex head screw? and when you sanded the second time after the filler primer was it wet or dry sand?
