The Raptor Has A Cool Aux Switch Bank - So Can The RAM!
  • Thread starter Thread starter sbourne
  • Start date Start date
If he'll share the file I will print them for people for cost+shipping.
Does that take the place of the trailer control section?
New panel that runs beneath the 12". The toggle switches that are there currently are turned into push button, and then there's a bank of aux switches beneath them.
  • Like
Reactions: c3k
Do you think we can hook up the top switches normally and run separate wires (not hooked up to the BCM) from under the hood for the bottom switches?
Thats what I was hoping for but I cant for the life of me find the part anywhere.
That switch panel is from the HD trucks. They've always had that as an option. You can see the exhaust brake switch in the pic on the panel by itself. I have these switches in my 2019 3500.
There is a thread on that switch panel. Ram claims it’s a no go. Doesn’t mean there is not a way to make it work though. Just not going to be easy, or cheap.
Been working on my own version to replace the sunglass cubby.
It has 6 switches and a Digital readout of PSI for my On Board Air System.
When I have the final design I will post the files on the forum for others to use.
Here is a Resin print I did last night. Some Elements need to be Thickened
and some dimensions modified. I also want to get some ABS type Resin.
Malodave
Malodave
OOOOORRRRRRR you could tell us how much $$ to make them for us :-)
I am using about 400 grams of resin to make it. It is about a 6 hour print
Time. I will probably make a version with just the 6 Switches at a different
angle to make reading them easier. Not many People will need my PSI
Gauge for On Board Air.
Malodave
Where can I get this?
I am still working on the fit, finish and mounting. Waiting for the new
ABS Gray Resin to show up too. Once I am happy with it, I will post the files
in DWG, DXF, and STL formats. I may include a Presupported Version for
medium sized Resin Printers. ie: Elegoo Saturn, Anycubic Photon Mono X, ETC.
I have the Mono X. Check for a MakerSpace near you with 3-d Printing
availability. That would probably be your cheapest option. I also may
do limited prints for about $50. I am using $25 worth of resin, then there
is about an hour of clean up, and then Shipping.
Malodave
Malodave
I would purchase one with the digital read out :)
I have finished the Two Versions of the switch panel. One with the Digital Display
for my PSI Gauge and the other without. The ZIP file includes DXF format 3D CAD files
and STL format files for 3D Printing.
The Picture in the truck shows what it will look like. That one was printed with ABS like
Gray Resin on my Anycubic Photon Mono X resin Printer. It still needed some minor
adjustments for size and the Screw. The panel uses a 6-32 x 1 3/4" Flat Head Screw.
Two mods to the Overhead Console are a hole to bring the Wiring into the Console.
I suggest using a Male/Female connector Outside of the console for easy removal if
Needed. The other Mod is to pull the little Rubber Bumper out of the console. Put
some JB Weld on the top of the hole. Drill and Tap for a 6-32 Screw. The Plastic is very
thin there for Threads.
I am going to order some Black ABS Resin to print it in. The Resin takes Paint very well
from what I have been told.
Test Fit in My Laramie
Close up on the Desk
Hole for Wires
JBweld in Bumper Hole. Drill and Tap for #6-32 x 1 3/4 " Flat Head Machine Screw.
Panel Meter from Ailexpress. These come in a bunch of colors. It took three tries to get exactly what I wanted. I wanted the first digit to blank out.
I de-soldered the Decimal Pin so it doesn't light up at all. IE when the yellow wire senses 3.0V it will display _30 instead of 3.00 or _3.0. 3 volts would
be the equivalent of 30 PSI in my tanks and 20V would display 200 for 200 PSI. 5V power and 2-100V sense.
DC to DC Boost PCB from Aliexpress. It will take the Nominal 12V and boost it up to 31 Volts. Use the Pot to set the output.
My Pressure Gauge PCB. LM7805 for regulated 5V out, LM 358 Dual Op Amp, 1n4007 Diode, 10K resistor, 56.2K resistor, 5K Pot.
This is sized to fit to the Back of the Boost PCB.
12V in goes to the LM7805. The 5V output powers the Display and the Sensor. The output of the sensor goes to the 1n4007
Diode for the Voltage drop. The Sensor signal now goes from 0 to 4 Volts ( 0 to 300 PSI) to the OpAmp. The OpAMP Multiplies
the Signal through the two resistors and Pot so the Voltage reading to the Display is 3-30 Volts. The Display would Show
30 to 300 PSI. My system has a max pressure of 235psi before a safety valve releases.
300 PSI Pressure Sensor from ALIEXPRESS. I took the connector apart and replaced the short Pigtail wires with longer ones.
Sensor needs 5 Volts in and outputs 0.5 to 4.5 Volts out.
There are 5 wires to connect 12v Power and Ground, Sensor 5V power and Ground, and the Sensor Output return.
Here is the Zip Files for the Switch Panels, Both DXF and STL.
Sorry, Forum will not let me post the ZIP Archive. You will
have to send me a PM to get the files.
Malodave
Probably going for $50. I am using $25 worth of resin, It is a 7 hour Print plus an hour to finish and cure it.
I will be ordering some Black ABS Resin, but final Painting and stuff will be up to you. Switches can be
had all over Amazon for Color, Legend, and if there is a small LED to light the switch when off and a brighter
one when on.
Malodave
