db252
So all parts came in today including @Jimmy07 custom harness which is super nice. I will be towing this weekend but don't have time to get everything done to get a true run. I did however install the rear custom harness and the rear sensor. There are holes in that location in the diagram earlier posted that line up with the sensor and I used that spot. They are just holes with no threads so zipties in the meantime will do or be permanent. I'll have to get to the cab module and find where that goes later next week.
Here are some current pics.
This spot is located behind the bumper area at the right side of where the license plate is. The top two holes were a perfect match for the sensor.
Got the main harness down and opened it up.
Removed the plugs and inserted the wires from the custom harness in their position. I already had a wire in spot 16 so I was informed to place that one in the 35 spot.
Back to factory look except for the new harness coming from it.
Sensor strapped in position with new harness connector.
Excess wire zip tied up.
