Tip for cleaning headliner water stain
Big thanks again to those who posted useful info on this thread. I've repaired mine now ... And will say this >
- The tip about hydrogen peroxide to remove the water stains on the headliner - Amazing! Voila, it's gone.
- The M-D product mentioned is spot on. Great quality, easy to use. The work is in stripping off OEM junk.
- While there, I also ran a bead of silicone around the brake / cargo light, plus did the shark fin just in case.
Bring on that next hurricane. Okay, skip that. I'll test with a water hose, brag to my wife and two kids. Done!
Cheers, Mike
Just wondering how this worked out for you? I just purchased all the items to do mine tonight. My truck sprang a large leak recently and I want to avoid the dealership tearing it apart.
this md gasket isnt shaped in a way that would make turns without kinking. Do you just snip a side halfway when going around curves, retracing the original gasket?
i know it seems that way just by looking at it but once you start putting it on it goes around the curves perfectly. no kinking and no cutting needed. its soft enough it kind of collapses on itself and allows you to curve it. Most people have been completely removing the old gasket. If you dont that will still saturate and allow water in
Why they use that crappy foam is a total mystery, how much money are they saving? Be careful when putting the brake light back on. I tightened the screws back to what I thought was OEM spec and they looked fine, for a day. Next day I checked my handy work to see cracks had formed around all 4 screws
A lot of cars use that same foam material to seal lights. My 08 Mercedes ml350 has the same seals for both tail lights. They are starting to leak now but I’ve had the truck since 2014 and have never had a problem until now.
Gentlemen, wanting to add a trinket to the conversation. I had the same issues with leakage last fall. Thought the 3rd brake was leaking so I purchased one aftermarket and installed. (thought the OEM was inadequate like some of you) The dealer later determined the sliding rear window frame was cracked in 4 places. (replaced under warranty) The truck was a dealer today and I noticed a water stain across the width of the headliner, so I asked them to verify where the leak is originating. ...................... The culprit is the 4 sunroof drains were plugged. Might want to check that on trucks with sunroofs. Thanks for the hydro peroxide idea and great information.
Hey Guys.
I just wanted to post this tip for cleaning the headliner after a water stain. I've been back to the dealer three times for the brake light/Rear glass leak. Each time they've been able to remove the water stain without replacing the headliner which I have been desperately trying to avoid since you have to remove the windshield. Finally on the 3rd time I was able to chat with the upholstery guy and ask him what they do. He said it's way easier than you think.
All they do is soak a rag with regular hydrogen peroxide and scrub the spot. It dried in no time and completely removed the stain.
Just wanted to put that out in case someone wanted to try this before replacing the headliner.
View attachment 58247View attachment 58248
Thank you I’ve got the same stain same place
