Has anyone here experienced any type of issues when installing the Fabtech 3” Lift Kit?
Everything bolted up fine, however, the front will not realign back to factory specs.
The alignment tech was telling me that he felt like the upper control arms were too short and he wanted me to put the factory ones back on. He was saying that if the caster was aligned properly that the camber was way off. The way it currently sits is what he described as the best he could get to make it drive straight with the equipment that’s installed.
I’ve been emailing back and forth with Fabtech support and they are saying that according to their R&D team, everything is fine on their end and they don’t know why it won’t align properly.
I provided Fabtech with the following measurements:
Center hub to fender lip distance:
Front Drv: 25.5”
Front Pass: 25.5”
Rear Drv: 24.5”
Rear Pass: 25”
Keep in mind that the rear passenger side is ever so slightly up on a curb so i think that’s why the measurements for that were a little off.
I also verified that the UCAs were installed as follows:
Driver Side: 44539
Pass Side: 44540
Here is a pic of the truck after the kit was installed. It did feel like the truck had a bit of reverse rake after the install, but i chalked it up as the possibility of the suspension needing to settle.
When i measured the rocker panel distance to the ground front and back it seems like the rear is about .5” lower or the front is .5” higher.
Front of the rocker panel to ground: 19.5”
Rear of rocker panel to ground: ~19.0”
I don’t know if those measurements will really tell you anything but it was an observation that I had made. It honestly feels like the front needs to drop by about .5” to 1.0” inches to me.
Even with those measurements being wonky (IMO) Fabtech has stated that their R&D team is not seeing any problems.
Has anyone else experienced an issue like this before when installing the Fabtech 3” lift?
I just don’t see where the issue lies considering the front part of the kit is just UCAs and coilovers…it’s not an overly complicated install by any means.
Front Drv: 25.5”
Front Pass: 25.5”
Rear Drv: 24.5”
Rear Pass: 25”
Driver Side: 44539
Pass Side: 44540
