2021 Ram 1500 etorque Big Horn radio volume
Ken2021Etorque
My new ram radio volume so low is not loud at all and when i raise to 35 i dont feel any difference then at 25, actually sounds lower at 35 and it seems like music volume comes and go.
Adjust the volume on your cell phone. I had the same problem when I first got my truck from the dealer. The volume on your phone has to be all the way up.
Ill try that thsnks
If you're using Android Auto you can't turn the volume up and down with the phone. It does it automatically, at least that's the way my phone works. If I plug my phone into my wife's car with no Android Auto I need to turn the volume up all the way manually on my phone. I put my truck volume at 30 when driving down the highway with my windows down. That's pretty loud in my truck. If driving with the windows up I feel 15 is a good volume. Not sure why you aren't getting the performance you want.
When phone is connected and or after getting a notification radio volume gets distored if i unplugged usb cord from the phone radio goes back to normal, i noticed the firmware still at 11
I've noticed something like that before. Hadn't happened in a while, but after Waze would give me a direction or something similar, the volume wouldn't go back. A work around I found that worked was to hit the microphone button like you were going to give a command then click off of it and the volume went back to normal.
Thanks, Ill try that, but imgaine 10 text or waze lol
