Crazy Dane
tag for intrest
			You, Sir are my hero. It's been driving me crazy that I couldn't see in my truck bed. I stumbled across this forum that gave me the exact info I needed. The lights cost less than $25 and the install took about two hours. Then you for sharing this info!My truck didn't come with the bed utility group so I missed out on the bed lights, which are very useful especially if you have a tonneau cover. So I found the wiring diagram and followed the wires from the third brake light down to the driver side rear kick plate, my plan was to tie into the wires suppling power to the cargo lamps which would turn on the led strips whenever the cargo light was on. I found the wire pretty easily (just a couple trim pieces to remove) it was a white wire with a tan tracer. From there its very simple, just install whatever light you want and ground one side to the body and connect the other side to the white and tan wire. And now you have bed lights for under $20. PS, If you run into an issue where the aftermarket lights don't work I recommend swapping the cargo lights mounted in the third brake light housing to LED, that has solved the issue for the couple of people it happened to. Here's a link to the set that I used.
Amazon.com: LUYED 2 X 1550 Lumens Extremely Bright Error Free 360-Degree Shine 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White: Automotive
Buy LUYED 2 X 1550 Lumens Extremely Bright Error Free 360-Degree Shine 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White: Back Up Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
View attachment 4851View attachment 4852View attachment 4853View attachment 4854
What size wire splice connector do I need for the wire in the cargo light?
That piece is Removable without taking the seat out. Can't remember exactly but I recall it being pretty straightforward but a bit of a pain in the buttDid your truck not have a plastic surrounding the wires? Couldn't figure out how to get it off with out removing the rear seats at the least
I just got up a bit earlier this morning and took the seat out, no biggieThat piece is Removable without taking the seat out. Can't remember exactly but I recall it being pretty straightforward but a bit of a pain in the butt
Sent from my Pixel 4 XL using Tapatalk
Does anyone know which wire is the reverse light for the taillights?? View attachment 30952
White/beige for left tail lampAny answers?
Gesendet von iPhone mit Tapatalk
do they light up with the engine running?My truck didn't come with the bed utility group so I missed out on the bed lights, which are very useful especially if you have a tonneau cover. So I found the wiring diagram and followed the wires from the third brake light down to the driver side rear kick plate, my plan was to tie into the wires suppling power to the cargo lamps which would turn on the led strips whenever the cargo light was on. I found the wire pretty easily (just a couple trim pieces to remove) it was a white wire with a tan tracer. From there its very simple, just install whatever light you want and ground one side to the body and connect the other side to the white and tan wire. And now you have bed lights for under $20. PS, If you run into an issue where the aftermarket lights don't work I recommend swapping the cargo lights mounted in the third brake light housing to LED, that has solved the issue for the couple of people it happened to. Here's a link to the set that I used.
They light up whenever the tailgate is open, it doesn't matter if the engine is runnng or notdo they light up with the engine running?
Thanks for this!! Best simple to the point how to I’ve found lol I thought the bed lights were in my build but turns out they weren’t and I’m not doing Mopar prices on those TeeheeMy truck didn't come with the bed utility group so I missed out on the bed lights, which are very useful especially if you have a tonneau cover. So I found the wiring diagram and followed the wires from the third brake light down to the driver side rear kick plate, my plan was to tie into the wires suppling power to the cargo lamps which would turn on the led strips whenever the cargo light was on. I found the wire pretty easily (just a couple trim pieces to remove) it was a white wire with a tan tracer. From there its very simple, just install whatever light you want and ground one side to the body and connect the other side to the white and tan wire. And now you have bed lights for under $20. PS, If you run into an issue where the aftermarket lights don't work I recommend swapping the cargo lights mounted in the third brake light housing to LED, that has solved the issue for the couple of people it happened to. Here's a link to the set that I used.
@Colton94 - did you resolve this? im experiencing the same issue.I installed my bed lights today, they worked at first but now the factory cargo light and the bed lights I installed aren't working at all. Does anyone know where the fuse is for the cargo light?
did you ever figure out the lights? I just realized my lights do not turn on when I open the tailgate either.Yes but just went with the 200 lumens. I haven't made it to the bed lights. My cargo lights don't turn on when I open my tailgate so I want that figured out first.
thanks for your quick response!Yes, I figured it out. The functionality is disabled deliberately by Ram. I also do not have a warning light that comes on to tell you your tailgate is open. There are several threads about the topic where people had their tailgates pop open while driving. Since the truck doesn’t know the tailgate is down, it can’t turn on the lights either.
As far as lighting, I got a batter light for my diamondback cover so I didn’t need to wire anything.
