My truck will kick the back end the tiniest bit with the traction control off but then the brakes start working to counteract the slippage.That's strange, I turn my traction control off and it certainly doesn't turn completely off but enough to slide around a bit if it's a little slick. Hoping my 21 on order is the same way, it's bad enough they won't give you the option of turning the t/c completely off as it is (well other than in 4lo).
Front axle isn’t engaged in 2wd.There’s still going to be wear on the front axle even when not engaged because front axle parts are still moving, even in 2WD. There was discussion on this a few years back. I’ve never had an issue, just make sure to inspect it Every now and then. No noticeable mpg hit for my prior vehicles, my Limited is new tho, I’ll see if there is one but I doubt it would be greater than 1 mpg.
Auto 4WD all the time?
As winter has firmly cast its spell here in the Northeast, I've been leaving my truck in 4WD auto all the time. There's a decent chance I may hit ice/snow/slush at some point during my daily driving, and I don't want to be caught without 4WD if I suddenly need it. My impression is that the 4WD...www.ram1500diesel.com
Correct, in 2WD it’s not engaged. I’m not disputing that, however there are still moving parts on the front axle while in 2WD only. You’ll still see wear on front axle components.Front axle isn’t engaged in 2wd.
From the manual:
For variable driving conditions, the 4WD AUTO mode can be used. In this mode, the front axle is engaged, but the vehicle’s power is sent to the rear wheels. Four-wheel drive will be automatically engaged when the vehicle senses aloss of traction. Because the front axle is engaged, this mode will result in lower fuel economy than the 2WD mode.
Not sure if "Home Despot" was intentional or not, but I like it."I've seen the tubes of sand at Home Despot and other big-box stores,..."
Oh, it was.Not sure if "Home Despot" was intentional or not, but I like it.
I had those on my previous vehicle, they really are the best. Theres no replacement for real winter tires.Nokian Hakkapeliitta 9 SUV's, ran them on my 2015 and will be putting new ones on my 2019 this coming winter.
Inner tubes work great for that. But I wouldn't use zip ties if you plan to use them more than one winter. Zip ties can become brittle and break, especially when exposed to the elements. Maybe some of the larger ones will hold up longer, but I'd use wire to close the one end instead of a zip tie.I haven't used sandbags in any of my Ram's but I did in my previous trucks.
Go to your local tire place and get some used tractor trailer tubes. Cut these in half and you can sew up one end with a zip tie and sew the other end with rope(allows you to open it if you need some sand). The rubber won't freeze and slide around like plastic sand bags. I use to get my sand free from the city and they augment it with a bit of salt.
So that's one method I've never heard of before--water. Makes sense.Minnesota and up near the Canadian border. Good tires are key. I never intentionally put weight in the back. If I needed to, I would just freeze some water in a bunch of 5 gallons bucks and use a rope to secure them in the bed. They'll stay frozen, won't make a mess, and can be easily removed. I know I guy that used to throw down a tarp and fill his entire truck bed with water. Once it froze, his little 2wd Toyata did much better in the snow.
When I had my 2WD Ram I used to just shovel some snow in the bed and when the weather warmed up it would just melt away .Minnesota and up near the Canadian border. Good tires are key. I never intentionally put weight in the back. If I needed to, I would just freeze some water in a bunch of 5 gallons bucks and use a rope to secure them in the bed. They'll stay frozen, won't make a mess, and can be easily removed. I know I guy that used to throw down a tarp and fill his entire truck bed with water. Once it froze, his little 2wd Toyata did much better in the snow.
