295/65/20s on stock rims?
Bowler
Hey guys I’m going crazy wondering what size tire I should get
I have a 2019 5th gen big horn no off road package Ram 5.7 hemi 4x4 long bed going to install the 2.5 motofab spacers from the trucks I seen I like the 295/65/20 Nitto ridge grapplers I looked at a lot of posts but so hard to pick , from the 285s to 295s I’m putting them on stock 20 inch rims
if u guys could please post pics of yours trucks and tire sizes would be great thanks !!
Thekidcasual
285/65/20 falken, eibach adjustable shocks set at 1.8 with ORP springs
GATORB8
Charlotte, NC
you went with the LT's to get 295/65/20? pretty heavy tire at 60lbs. no issues?
No issues. I have 3.92s so that certainly helps with the power. Ride is no worse than I expected.
At least they’re lighter than the flotation sizes.
Other than wearing out the stocks, I’ve had LT load range Es for probably the last 20 years, so my expectations probably aren’t the highest.
mcp6530
Chicagoland
thanks - yeah, never had a truck before or LT tires. I like the look of them but concerned about noise and comfort.
GATORB8
Charlotte, NC
Remember you'll get some cushion with the larger sidewall, for a point of reference since you have a bimmer, the truck still rides waaaaay better than my old 335is on 19s ever did.
Noise on the Ridge Grapplers isn't bad, slight hum but ANC takes care of most of it.
Ram Dude
295/65/20 NRG’s on stock 20” Night Edition rims (2wd 1500 with 3.5” lift)...It works, just a lot of trimming with my setup to prevent rubbing (including removing rear mud flaps from front wheel wells). From what I’ve read here from folks with 4wd and ORP/ORG you may not have to trim as much.
mcp6530
Chicagoland
looks great - i have same truck and wheels. only leveling front though. How is the ride now with LT tires vs p tires? assuming you came from p rated?
mcp6530
Chicagoland
thanks - my beamer is pretty quiet :) i really want the AT3 285/60/20LT but just don't want the ride to get too stiff. I guess I have 30 days to decide with toyo's program..
Ram Dude
Ride is awesome (in my subjective opinion 😂)...No I’m sure on a smoothness factor nothing compares to stock setup but for 3.5” lifted truck with 35’s it rides pretty smooth. Mine are load range E1.
Bowler
Looks good guys thanks for posting I might be going with the 295/60/20s Nitto ridge
Bowler
Anyone think the 295/60/20s will stick out in stock big horn rims ?
Bowler
Oh ok so it should be pretty well flush ? I don’t have the flares on my truck
GATORB8
Charlotte, NC
Bowler
Your fenders stick out more then mine ? I have the 2019 big horn long box and I notice u have flares
