Received my $8 Mopar SRT oil filters today, then decided to order a fumoto valve to install before I do my oil change. That won't be here till Thursday.
I put the fumotos on everything I own. Awesome product.
Pictures simply can’t do justice to how much different this looks in person from where I started. Really satisfying results from ceramic coating. I’m excited to see how it performs and holds up over time now
Wow, it looks like liquid.
Did you order from Steve White Parts? If so, how long did it take for you to get it? Ordered mine on April 10th and I've yet to receive any tracking updates.
BAM Wholesale, it was on backorder for a couple weeks
Alright here is the install video for the Evil Mfg 3rd brake light.
In full transparency, this is not a mod for the novice. There’s a considerable amount of wiring and some grinding/cutting required to fit everything together.
Super long video but there are a ton of steps and wanted to make sure I covered them all.
Enjoy!
This looks fantastic! Solid work. You have the bilstein 5100s at setting #4 right? How much rake did you retain? If I remember you left the factory UCA's? Can we see a side shot of your truck? Curious to see what setting #4 looks like.
I’ll have to get you a new side pic of the truck not in the driveway. One thing I’ve learned on the Bilstein install is each of our trucks have different weight distribution. I have Ramboxes and pano, which collectively must put more weight towards the rear of my particular vehicle. Most others go #5 on their Billy’s, but when I did that install I was 0.25” high in the front. I’m now 0.25” rake, or so.
Mine is at the shop getting core 4x4 upper and lower control arms, panhard bar , and a hellwig sway bar. Next up better rear shocks any tips?
I did mine myself and fairly certain I need a shoulder surgery after those bolts. They are NO joke without a lift.
Those look awesome!
Those look awesome!
Yes since i lowered mine I have less space to get in there so I figured 300 bucks let them deal with it
Seen these on Facebook so thought I would give them a try. Built right Velcro panels and bags with assorted d rings and elastic clips. Let’s me keep everything off the cab floor and organized. Will hold all my PPE gear for work and then some.
Does the windows have a safety up feature, so when these are installed and the window goes up, when it hits them does it force the window to go back down or can anyone install these?
Yes, there is a safety up feature, but with the visors properly installed, it isn't an issue
Had to brush the dang snow off my truck after work! Only I’ve already taken the winter stuff out of my truck...So much for spring, thanks Vermont. 🤣
mine did a few times when I fist installed. After the 5 up/downs you do after install that stops. I have had on 3 months and it has done it one time but went right up the 2nd. Very easy install. I would make sure to follow instructions. On the rear (Quad cab) pull the weather stripping out and put the brackets in the window channel. Most install videos they just slip it in and they can slide the bracket. When I did mine the bracket was very hard to move(no slide}.
Love mine.
  • Back
