z0n3
- Jun 16, 2019
What kind of rake did you retain from front to back? I still go back and forth on setting #4 or #5 with my ORP truck.Just got back from having them installed. The ride is WAY better than factory! Much more composed. Bumps are barely felt and the rocking back and forth is nearly gone. This thing is going to handle awesome when I do 5160s in the rear and add a Hellwig sway bar. Now, if only I can find a set of 305/55 r20 in stock.
Here is the ball joint angle at setting #5 with factory arms.
