fubar414
- Apr 2, 2021
For the bed lights each side is its own strand of led lights, so I just tapped into the factory bed light of each side. They turn on when I press the unlock button on key fob, open door, open the tailgate, and when you press the factory bed light switch it’ll turn on off.
The running board lights I tapped into the black and yellow w/purple stripe wire on the driver side, footwell courtesy light. The lights will turn on when unlock, and open the door. I poked a hole in the rubber grommet and snaked the wire through there to get in the cab.
I ran the passenger side light wire to driver side, and ran 1 wire into the cab.
