Ccamacho1231
- Nov 11, 2020
So if I get the 2.5" rear coil springs I have to get custom shocks made?
No. they'll work with any of OE shocks from Fox or King or Icon made for your truck. You can get longer shocks if you wanted from any vendor up to 29.75" extended.So if I get the 2.5" rear coil springs I have to get custom shocks made?
Yep.so if i get 6112 for front and 5160 rear i should be good roght ?
Can you expand on the "Icon dual rate yada yada"? I am going to have 3.5" of lift in the front and I am trying to determine if I should run the Icon 1.5" or the Clayton 2.5" rear coil springs.Hey peeps, just joined the forum...facebook guys arent really much help. This thread is by far the coolest thread ive seen, most informative. I will say im a little lost, I hope you guys dont mind me asking a couple questions for the rear. I would like to swap to claytons 3.5 coils. Currently stock with kings 0-3 on rear, 0-3 on front coilovers. I have been through icons dual rate yada yada...ended up taking them out. explain later. Is the 3.5" a true 3.5 lift of just under? If i do 3.5 coils, does the relocation bracket help for ride quality, needed? I will need to get extended king shocks, just unsure how long..waiting on rep to email me back., sway bar links i will get extended. Anything im missing? coils, links, shocks, relocation bracket?, brake line extension bracket? thank you so much in advance
What are you doin for achieve the 3.5” up front if I may ask??Can you expand on the "Icon dual rate yada yada"? I am going to have 3.5" of lift in the front and I am trying to determine if I should run the Icon 1.5" or the Clayton 2.5" rear coil springs.
Thanks
Currently torn between:What are you doin for achieve the 3.5” up front if I may ask??
I have a clacking sound in the back and it looks like my springs may be the reason. It seems the softer portion of the springs is indeed hitting each other. The sound is driving me nuts!Since most of the Clayton info is this thread i thought it'll be a good idea to leave this here as well for others to see.
If you're getting a clacking noise with your Clayton springs is because the dead coils might be hitting each other when the spring compresses, you hit a bump, or a pothole etc, etc. It's kind of a nature with long progressive coil springs. Some people may experience this some others may not, trucks are not created equal. but it's a super easy fix.
I've had that situation with Icon 1.5" springs and with the Claytons as well. My truck runs heavy in the back at all times (500lbs of weight in the bed, recovery gear, steel bumper, swing out rear gate carrier, Full spare, etc etc), and when travelling i tend to add more weight in there as well. Our travel may involve miles of washboard roads, sugarish sand washes or mountain dirt roads with rocks etc, so i need a suspension able to whistand that stuff and coils that can carry weight but also coils that feel nice when the truck bed is not loaded to the roof
2020-07-21_04-46-31 by RAM RSM, on Flickr
Because of this the soft portion of the coils may hit each other if you get to experience the clack noise, you'll see the marks on the springs if that was the case. If you hear some noise and it happens to bother you all you need to do is add some sort of coil spring insulator.
You can buy for example Eibach spring insulators, eibach CS5002L, 1 per coil
2021-02-26_01-36-27 by RAM RSM, on Flickr
Then cut 3 or 4 pieces and fit them in there as needed. the sleeves come with a glue inside so make sure to fit your pieces where you want them the first time, i tried to push that first SOB at the top towards the inside and it won't move. I can remove it and fit another piece but i'm not that anal haha.
2021-02-26_01-36-51 by RAM RSM, on Flickr
Have fun.
Having similar issues so I ordered those. Are they only needed on the rear of the springs?Since most of the Clayton info is this thread i thought it'll be a good idea to leave this here as well for others to see.
Have fun.
Looking at your set up you are sitting at roughly 3" in the front? 2.6 with the 6112 all the way up and the +.5. and 2" in rear. I think you sitting perfect but I will bet at just 2" with the BDS 2in performance kit. I did order the Carli 1.25 for the regular 1500. I called them and they said I should be fine. If not ill look into these and maybe look at the softer rate. I also thought about ordering some Timbrens, just in case. But I dont want to limit the travel of the carli springs. Ordered it all yesterday, so we'll see.Or there is Dobinsons coils, I have them in my truck they give you 2inches of lift and are a heavier rate. They also have a softer rate which is still more than stock and gives the same 2” of lift.
I’ve got a Rci 58” bed rack which is roughly 80-100lbs I would say maybe little more then the ikamper tent is 160 lbs and didn’t really notice it dropping height wise at all.
