Shifter Autocorrect Avtive
BradfordRick
I want to turn off the engine and leave it in Neutral, however the Shifter Autocorrect keeps putting in Park. What to do?
Neurobit
RAM Sorcerer
Texas
That's because of the AutoPark safety feature. If your truck is equipped with 4WD, then the only way to get around this that I know of is to put it in 4WD Low, which disables AutoPark.
Curious, that are you trying to accomplish?
BradfordRick
My parking brake is sticking abit, so I want to get it up off the ground and turn the wheels by hand to see which side is sticking. ( I tried the 4 wheel low...no help )
Neurobit
RAM Sorcerer
Texas
Oh, so did AutoPark still engage in 4WD Low? Interesting. Not sure what else to recommend. Perhaps others will know.
Pls update your signature with your vehicle details so it's easier to help if you have other questions.
Cheers,
piening2150
You can pull the manual neutral strap under the dash on the left.
ElkoNV
My dog thinks I’m cool.
NV
See attached. It is from the manual on how to recreationally tow a 4wd. It is how to get the transfer case in neutral with the transmission in park.
  • 4 wheel neutral.pdf
JustADriver
do you know how I can turn it off because I accidentally turned my truck off and it stayed stuck at park I tried to turn it to drive but it won't move.
