Shifter Autocorrect Avtive
BradfordRick
I want to turn off the engine and leave it in Neutral, however the Shifter Autocorrect keeps putting in Park. What to do?
That's because of the AutoPark safety feature. If your truck is equipped with 4WD, then the only way to get around this that I know of is to put it in 4WD Low, which disables AutoPark.
Curious, that are you trying to accomplish?
My parking brake is sticking abit, so I want to get it up off the ground and turn the wheels by hand to see which side is sticking. ( I tried the 4 wheel low...no help )
Oh, so did AutoPark still engage in 4WD Low? Interesting. Not sure what else to recommend. Perhaps others will know.
Pls update your signature with your vehicle details so it's easier to help if you have other questions.
Cheers,
See attached. It is from the manual on how to recreationally tow a 4wd. It is how to get the transfer case in neutral with the transmission in park.
do you know how I can turn it off because I accidentally turned my truck off and it stayed stuck at park I tried to turn it to drive but it won't move.
Hi. Did you ever figure out how to get it out of shifter autocorrect active mode? I'm currently having this issue.
