Amazing. I also found a post where a guy claims to put in a few drips of Air Brake Defrosting fluid into the hose out back by the right rear taillight assembly. Still working to understand this but I believe the process is the air brake defrosting fluid's vapors rid the system of condensation, which in turn prevents freezing in the lines, which in turns alleviates the compressor from what I'm not exactly sure but I guess its excessive pumping of air through blocked hoses, and this in turn will (should prevent) the situations in which one end of the truck is slammed to the ground while the other end is way up in Off Road 2. If someone could review my thinking and let me know if this is correct...
I also am trying to understand whether these systems are fill with air or nitrogen gas?
My wild guess is Nitrogen gas and that air is the contaminant that turns to water drips under compression cycles and which in turn freezes from cold temps.
Again not sure if this is right but I in order to have ice you have to have water and water doesn't get into these systems because you drove your truck in the rain. It gets in there through repeated compression cycles correct?
