CAI, what did you end up installing and why?
Joshua022
I installed the Corsa CAI and followed the instructions exactly. Didn't have to disconnect the battery and had no issues. Chose the Corsa for looks and price since you don't gain much from the intakes other than sound and minor flow increase.
Dang might need to take her in to get looked at. Running 89 fuel as recommended the knock just seems worse after the CAI install
The Vararam instructions said to disconnect battery. Wouldn't hurt to give it a try.
redneck
s.w florida
Who's got the best price on the ram air intake from Mopar the guy on eBay has make an offer but he won't take 700
RAM Patriot
Clayton GA
That's just a safety measure. It's possible to short to ground accidentally with a wrench whenever you work on a vehicle.
You are correct, it is good practice to disconnect the battery when working with electrical, but that's not the only reason why they say to disconnect the battery when installing an intake?
The ECU needs to re-learn hence we disconnect the battery. :unsure:
Ginger_Beast
I had a really hard time deciding between the Vararam Air Grabber and the MOPAR Ram Airflow. None of the others appealed to me because the stock box is so well made and the other ones just didn't seem to do much of anything at all; some of them not even offering any changes to sound (which is what most people say is the only benefit you get anyway). To address your question:
I decided on going with the MOPAR Ram Airflow. (but it was tough). Here were the pros and cons lists I had made. I am sure there are more of each, but these were the things that mattered to me, so YMMV.
Vararam pros:
* Significantly cheaper ($330-$370ish)
* Nice 'old school' look. I personally like the look of the exposed filter; Especially with the Hemi Orange cover.
* Well documented HP gains. And even if *I* don't get the full 30HP, getting half of the advertised amount is still more than the full advertised amount from many other options.
* Additional 'dam' in front of the radiator to help direct the air. Not 100% sure about the effectiveness with this vs without it though.
Vararam cons:
* Not MOPAR, so the POTENTIAL for warranty issues (I know, I know, "they gotta prove it caused issues", but I have already been through an issue where my local dealership wouldn't even run a diagnostic because of aftermarket exhaust).
* Sub-issue with the above, but due to my dealer experience, I would need to uninstall the Vararam and reinstall the stock intake for each service appointment and then reverse the process after the appointment. Even if it only takes 30 minutes, that is significantly more opportunities for stuff to get broken/lost.
* Need to remove or modify the shroud. I don't think the shroud *technically* does much of anything, but it looks cool. And lets be honest, if you are buying a CAI, you care how cool it looks (and sounds)
* Not MOPAR and I don't want my $50K truck with a 10yr bumper to bumper warranty being turned away because the service manager is a d*ck.
MOPAR pros:
* OEM product. No issues with dealer. I can't stress enough how important this was for *ME*
* It also looks really good. Different style than the Vararam, so its like comparing sweet apples vs tart apples, but I like them both for different reasons.
* Has similar (identical I think) performance gains to the Vararam. As far as I have been able to find, it is actually based on the Vararam anyway. The construction and design is extremely similar.
* Retains the shroud look (actually replaces the stock shroud, but the idea is the same)
* Plenty of space and opportunities for paint/decals for making the engine bay a bit cooler/different
MOPAR cons:
* Holy cow it is expensive. I paid $848 including shipping for mine. The day it shipped I did find a place that was within driving distance that I could have got it for $760 though....The cheapest I saw it was $730 but it had like $300 shipping so.....
So, honestly, if I wasn't so concerned with the potential warranty issues, I would have went with the Vararam. If you just have a standard warranty or have a good local dealer or for any other reason are not as concerned with potentially running into issues, then I would recommend the Vararam. But for me, paying $450-500ish more to be 100% sure that my extended warranty won't be denied in 7 years because I put on something that does not say MOPAR was worth it.
As for improvements noticed:
* Sound - Sound at idle is almost no different. Sound with low throttle, but still accelerating (like out of my driveway) has a nice sort of growl from the front end. Mid level throttle is overshadowed by my exhaust, so it is difficult to say if there is much of a change there. Heavy on the gas while on the highway/interstate produces a noticeable front end sound. I like it.
* HP/Torque - So...my truck has a full Kooks Headers and Exhaust system (headers, cats, mufflers, pipes) which dynos it at 450HP to the wheel already. While I have not had the truck dyno'ed since installing the Airflow, my seat of the pants dyno says: Not a ton of improvement until I accelerate over like 75-80 mph. and since I drive like 80% in the city, that is not often.
* MPGs - Here I can positively report that there has been a very noticeable increase. Prior to install, my average MPG was a steady 12.7 (remember, like 80%+ of my driving is stop and go in the city driving with plenty of idle time at lights). I have had the intake on for about a week and even with some.....spirited....driving to notice the sound differences, my average MPGs are up to 13.3. So not a HUGE change yet, but when the fuel economy is that low, an additional half mile per gallon average is decent. And I think it will increase even more if I can drive like a normal person....
In my opinion, I paid for peace of mind and to avoid hearing "I told you so" from my wife. I am not claiming the Ram Airflow is superior to the Vararam. Honestly I think they are probably VERY similar...except in cost.
Hope this helps.
Rambro23
Try BAM Wholesale and use "minus20" for shipping discount.
Ellisstrong
Atlanta Ga area
Vararam pros:
Vararam cons:
MOPAR pros:
MOPAR cons:
Hope this helps.
You are saying that you are putting 450hp to the wheels with just headers and exhaust?!?!?
Vararam pros:
Vararam cons:
MOPAR pros:
MOPAR cons:
Hope this helps.
You were worried about warranty issues from an intake, yet you have headers and a full exhaust, that are not Mopar and could cause warranty issues.
Ginger_Beast
It's a long story. It basically boils down to: The dealer sold me the truck and an extended bumper to bumper warranty for the truck without disclosing it had a full aftermarket exhaust system. Then, when a check engine light came on the day after I bought it, they (eventually) realized we had a warranty agreement on the truck they had sold me and since they told me everything on it was stock they had to cover the stuff. So my system is covered as if it were a stock system.
That's the short version.
GadgetMason
South-central MA
Vararam pros:
Vararam cons:
MOPAR pros:
MOPAR cons:
Hope this helps.
A great write-up and a good read. Thanks for taking the time! Already on my definite adds list.
Ginger_Beast
No problem, glad it helped. Please remember that this is just my experience though. I'm not trying to necessarily advocate for or against any particular intake. If I had a Vararam to actually put on and compare then I could offer more.
Maybe I should call them.
GadgetMason
South-central MA
Many of your reasons aligned and amplified mine... Was good!
Ginger_Beast
Well, to be fair I probably shouldn't have said to the wheel. I know there is another kind, but I don't know what it is called or exactly what it means. I am not a gear head by any means.
But I do know of that my truck got just over 450HP on the dyno after the headers and exhaust system was installed. It is the truck that Kooks used to design and test the fitment of their system with. Therefore it is the one that they used to base all of their numbers on. Basically, they put the system on and then....did mechanic stuff, I don't know....to squeeze ever last HP out of it because they were only allowed to claim whatever they could get from my truck (I assume this is either an internal rule or just a CYA practice to avoid any false advertising claims).
They walked me through the process they did to the truck and said it ended up going slightly over 450 (didn't say exactly what), but they were able to advertise as "55+" HP increase, so a nice round marketable number.
You can see my truck in their promotional video for the 2019+ body style system on their website. It has all the numbers on there as well. 55+HP and 80 pounds of torque.
