ChadT
- Oct 20, 2018
On a Rebel 34.5 & 12 Wide Will Clear without rubbing or modding, 12.5 will rub the small mud flap.
What kind of Tire?
What kind of Tire?
Cooper STT Pro
Man that is one beefy tire!!
Hi Kliffy77, is this on stock Rebel wheels?On a Rebel 34.5 & 12 Wide Will Clear without rubbing or modding, 12.5 will rub the small mud flap.
In my case no I’m on fuel wheels but i think it can be done on stock wheels.Hi Kliffy77, is this on stock Rebel wheels?
12.2How wide can you go on a stock Rebel wheel without rubbing issues on upper A-arm? Obviously, I mean without using spacers.
Sounds like a nice setup! Do you happen to have some pics of the entire truck? I would love to see how it looks.Here is a factory TRX wheel on my Rebel with factory tire Goodyear Territory A/T 325/65/18 this tire is 34.6” tall and 12.8” wide , the wheels are 18” by 9” and another picture with a 1.5” spacer
I love it! Are you running leveling links and Daystar spacers?Sure here you go
Only the Revel links front & back with maybe only 1” more with them so it doesn’t ruin the ride i installed the daystar spacers & on the Rebel on full droop the upper control arms touched the strut can so i took them offI love it! Are you running leveling links and Daystar spacers?
Thank you for sharing that. I’ll try raising the front 1” on my Rebel as a starting point. I think that’s probably the sweet spot for maintaining the ride comfort.Only the Revel links front & back with maybe only 1” more with them so it doesn’t ruin the ride i installed the daystar spacers & on the Rebel on full droop the upper control arms touched the strut can so i took them off
That’s what i foundThank you for sharing that. I’ll try raising the front 1” on my Rebel as a starting point. I think that’s probably the sweet spot for maintaining the ride comfort.
With regards to your Fuel wheels, what size did you get 18X9 or 20X9 and what offset? What size tires did you install? I am thinking about Fuel Covert wheels with bigger than stock tires. I have not lifted or leveled my 2019 and don't want to unless I have to!
That’s what i found
