Jmmoore3
- Jan 23, 2021
Did it seem to help? Noticed a little bit of squeaking from my bushings as well.Removed, cleaned, re-greased, and reinstalled my Hellwig sway bar. It was getting a little “creaky” when lowering the truck. Went with the middle setting this time, and I’m liking it so far!
Thanks! Not bad at all, a little stiffer than stock, but tires handle well and are quiet!That looks great!
How the ride?
Oh, yeah!Did it seem to help? Noticed a little bit of squeaking from my bushings as well.
Glad to see a install with thesePut on new headlights. Love em!![]()
Sent from my SM-N970U using Tapatalk
Really nice job!! Which floor mats are those?I built my own storage box for under the seat & carpeted it. I wanted something that maximized every inch of space & could fit a sub under the seat eventually so this is what I came up with! It looks factory in my opinion. Ram Bins still open fully, and your feet don’t kick it since it’s angled. Plus I notched the front so that it hooks into the groove for the ram bins so it stays put without having to screw it down to the cab.
It's cool they sent them from free, but it's just silicone grease. Most parts stores carry itPulled the Hellwig off today and reapplied some grease to the bar, and bushings. It developed a squeak when I transferred it from my 2019. Hellwig was nice enough to send me a few packets of their grease for free too!
Thank you! They’re just the stock matsReally nice job!! Which floor mats are those?
Nice job, looks super clean.......I'll take oneI built my own storage box for under the seat & carpeted it. I wanted something that maximized every inch of space & could fit a sub under the seat eventually so this is what I came up with! It looks factory in my opinion. Ram Bins still open fully, and your feet don’t kick it since it’s angled. Plus I notched the front so that it hooks into the groove for the ram bins so it stays put without having to screw it down to the cab.
Yeah it was, I could have certainly gotten some silicone grease but they first offered to send new bushings and I had no need so they insisted on sending more grease packets. It’s appreciated that they actually stand behind their product and do everything they can to keep their customers happy.It's cool they sent them from free, but it's just silicone grease. Most parts stores carry it
Did the same today although mine would squeak when going over speed bumps, greasing the D bushings definitely fixed it!Removed, cleaned, re-greased, and reinstalled my Hellwig sway bar. It was getting a little “creaky” when lowering the truck. Went with the middle setting this time, and I’m liking it so far!
Thanks! Haha I can give you info or dimensions to make your own but my back can’t handle making another one lolNice job, looks super clean.......I'll take one.
I was going to ask you about the Atturos. I've got the same wheels and they have a noticeable hum to them compared to the nittos on my buddies truck. Good wheels, and good price, but I'll be getting nittos next time.Thanks! Not bad at all, a little stiffer than stock, but tires handle well and are quiet!
I found a stock 4x4 so I took some pics with it lol. This is with the BDS 4” lift and 35s. It’s actually a bigger difference than I remembered!
That’s correct because I only lifted the rear 1.75”Is it me or does there seem to be a much bigger difference on the front side?
That’s correct! I did the 4” lift up front and 2” lift in the rear but for some reason I got 4.75” up front and 1.75” in the rear. Add in the tires and basically I’m 5.75” taller up front and 2.75” taller in the rear. With my tailgate down my bed is actually only 1.25” taller than stock.Is it me or does there seem to be a much bigger difference on the front side?
That’s correct! I did the 4” lift up front and 2” lift in the rear but for some reason I got 4.75” up front and 1.75” in the rear. Add in the tires and basically I’m 5.75” taller up front and 2.75” taller in the rear. At my tailgateIs it me or does there seem to be a much bigger difference on the front side?
thank you! My front end sits 1” higher than the rear.Makes sense. Always interesting to see what the real life “inches” end up being
Love the stance
