BORA Spacer Install
I have a set of 1.5/2.0” spacers for my brand new Ram 1500, and reading the install info from BORA I am a little gunshy of installing them myself. I’m handy enough with tools and have a torque wrench capable of the torque needed to install. The problem is that if a qualified shop does not install them, the warranty is then voided and I would also imagine that my insurance company would fault me in the case of an accident due to failure. What say you diy gurus? Go for it or lay up and let the shop install?
Extremely simple to install just torque them properly and they'll be perfectly fine! But if you are worried then your local tire shop should do them pretty cheap..
BORA is the best spacer you can buy, so I wouldnt be too concerned with failure or them not backing their product in the rare case something does happen. Just my 2c
If you got a torque wrench.. save your toonies man! Look up torque spec, tighten in star pattern and your done!
Super simple
Welll with that logic why not just buy wheels with the offset you want instead of using wheel spacers on that $75k truck?
I like the stock 22”s that came on the truck to begin with. Thanks for the guidance though!
There Is no reason to be scared of using Bora spacers, they are hubcentric and top notch. If you know how to remove and install a tire you can put on the spacers yourself no problem.
Just I side note, I bring my vehicles to Discount tire for all tires and wheels and they will not put on your wheel spacers for you. So that’s something to think about
