Soft shackles won't give you a lifetime of use compared to steel. They are also more expensive for quality pieces. What they do give you is significant weight savings and ease of use. For casual users, they may be not be the best use of your hard earned dollars. But, if you want something light and durable, the soft shackle rules. TRE ( Tactical Recovery Equipment ) makes some quality gear, if looking.
Soft Shackle 5/16 Amsteel Blue 29K#
Made in the USA. These are not cheap imitations. Soft Shackle made from 5/16" Amsteel Blue. Our Shackle uses a uniquely designed button knot and self-tightening loop that will not slip during use. Use Soft Shackles to connect winch lines and straps to attachment points where you would normally...
highmarkoffroad.com
Quick Link - Dipped Soft Shackle
The most durable soft shackle available for UTVs, Jeeps, Overlanders, Rock Crawlers and Desert Racing. We also service Agricultural and Mining needs.
Extreme Duty Soft Shackle 3/8" X 10″
Soft shackles may be used as a lightweight replacement connecting rigging for common steel screw pin shackles. The Factor 55 10 inch (pull to pull length) Extreme Duty Soft Shackles are made in the USA under the uncompromising Factor 55 quality standards.
3/4 Soft Shackles with Quick Release - 30,000 lb. Breaking Strength - for vehicles up to 10,000 lbs.
3/4 Soft Shackles - Safer, Faster & Easier vehicle recovery connections - Alternative to D-Rings - Vehicles up to 10,000 lbs. | Towing & Winching Shackles
The argument for soft shackles is there is not a heavy piece of steel flying around if a shackle or tow hook disconnects or comes apart or a tree or rope breaks. It is also softer on pieces it is connecting to. Give the cost of just travel to go off-road, plus starting with a $50k-$65k truck with another $2.5k of wheels and tires plus a lift/level...somehow this doesn't seem expensive. Then there are air compressors, tire deflators, traction mats, jacks (exhaust bags, bottle jacks, high jacks, the ARB hydraulic toe jack), etc....no shortage of things to spend money on.
Cable dampers are another think rarely discussed. I did see on video where the off-roader used 5lb ankle weights. They easily stay on the cable or rope and have the needed weight.
