Laramie led to Limited led
RHeller1
Is it a simple swap going from a Laramie LED to a Limited LED with the dual projectors?
Doesn't the Laramie have a totally different headlight structure and size? If so, it's a lot more work than just swapping lights. The grill and the facia below the lights may all need to be replaced to match up to the Limited's lighting format.
As mentioned above, no this isnt a simple headlight swap. The fascia panels below the head light are different, which would then probably require the limited grille as well.
As the others have said, you need the lights, the part below the lights and a new grill. There are posts on here that others have done it so it can be done.
that's part of the reason I ended up getting a limited over a Laramie. Thought about doing the same if I got one, but noticed it's pretty much everything between bumper and the hood is different and has different brackets.
