20Ram4X
- Jan 16, 2021
According to my window sticker I should have a peg leg diff. No limited slip mentioned. I turned off TC and was very happy to see this...
You’re saying that turning TC off doesn’t defeat this?They also employ what's called an e-diff. Basically it applies the brake on the wheel that's spinning to transfer torque to the wheel that isn't. So it acts like an lsd without actually having one, though in my experience there is a slight delay with the e-diff where I find the lsd in my ram to be near instant sideways action in the snow
Sent from my Moto Z (2) using Tapatalk
That would be my guess, though I really can't say for sure.You’re saying that turning TC off doesn’t defeat this?
It should, but stability control is separate and could also play a factor if it thinks the vehicle will travel in an unintended direction due to wheel slip.You’re saying that turning TC off doesn’t defeat this?
I thought I made a mistake not buying the limited slip but when I put it into 4x4 it hops when turning slow just like my Rebel did with limited slip
Actually, the hop is because the front wheels are trying to turn a higher speed than the rear when the steering is turned hard. In 4 HI the transfer case is trying to turn both driveshafts the same speed.The front wheels “hop” when in 4H because there is too much traction available.... it’s unrelated to the rear axle’s limited slip.
If that's what your build sheet says then that's what you got. 4x4 does not automatically get one of them. ORG, BTS and Rebel get the rear locker, night edition gets the anti-spin. And either one can be added as a standalone option.My build sheet says conventional rear axle. I would think a 4x4 should have some sort locker or LSD. How do I know what i have?
I agree, my 1500 had the anti-spin but my 2500 does not. I barely used 4x4 in my 1500 out on the main roads even when they weren't particularly clearly, my 2500 I ended up driving in 4x4 because I could barely leave a stoplight. But I wasn't about to settle for a white truck for the next 5+ years, I'll add a diff at some point in the future.The open dif really sucks. It's the only thing i really dislike about my 19 Laramie. I got so used to drifting my 05 diesel everywhere like a jet boat, using a bit of throttle oversteer to finish off corners, cannot do that in my little one wheel drive gasser, it just refuses to predictably set a slip angle with one wheel spinning. The pedal delay makes it even worse, coming off stoplights i have to preload the gas pedal to smooth the launch transition, otherwise it's slip-n-hop time.
