doolin64
If I go in for service, do I have to "turn" my truck back to stock?  I'm debating on getting the Alphaobd to adjust for my tire size.
			May vary dealer to dealer. I would probably just remove the security bypass but leave all your settings.If I go in for service, do I have to "turn" my truck back to stock? I'm debating on getting the Alphaobd to adjust for my tire size.
Mine runs about 5% optimistic sometimes, so hand calc is about the only wat to get accurate MPG.Does anyone know if there's a correction for fuel consumption (MPG) anywhere? Over 3600 miles and 7 fill ups, I've noticed my truck's calculated MPG is off (optimistic) by about 6%. Truck is 100% stock.
OK.. Another brand of vehicles I'm familiar with does have the ability to correct this by tweaking a channel in the Instrument Cluster with a scan tool, and I was hoping FCA might also have a provision for it.Mine runs about 5% optimistic sometimes, so hand calc is about the only wat to get accurate MPG.
VehConfig 1: Auto High Beam- YESGood Evening, New here but looking to add auto high beams to my 2019 Laramie. I have the new mirror just havent installed it yet. I'm looking for the settings that need to be changed in AlfaObd to get these to work. Thanks
Thank you very much!VehConfig 1: Auto High Beam- YES
VehConfig 3: Interior Electrochromic Mirror Present- YES
2014 CBC Config I/O & Feat: Auto High Beam Module Location- ECC AHBM
Lin & Misc: Smart Beam Present (AHBM)- YES
CustSetMenu 1: Auto High Beam CSM Present- YES
That can’t be changed since it’s part of the heated seat module programming.Does anyone know how to change the remote start comfort system “start” temperature? I know it will auto trigger at 40 degrees as a factory default, but I’d prefer it to start at a higher temperature. I couldn’t find any other posts on this, or a obvious setting in AlphaOBD, but seems like something that would be easily done.
Thanks
You can’t change the way remote start behaves, but you can lower the percentage of fuel remaining for when the low fuel light comes on.Anybody know if there’s a way to keep the remote start from shutting itself off when you’re on ‘low fuel’? My low fuel light comes on when I have 1/4 tank left. Leaving the truck running in idle isn’t going to cause it to run out of gas in 10-15 mins.
Cluster: Fuel Tank 1 Calibration, LFWThanks. You don’t by chance know what setting that is?
