I'm curious as well. I know I would never see it, but knowing it is delayed is what has kept me from buying one.I'm with SpeedyV, I would love to know if you installed the Diode Dynamics "Turn as Tail" modules and if they worked.
I like hearing that last part (about the color). But yes, every video makes it obvious...but I’m referring to the initial delay when you first turn on a turn signal, not the ongoing (and nearly unnoticeable) delay.Just throwing this out there. The delay is literally a 1/4 second on the the opt7. Do you really think anyone behind you notices, you sure can't from the drivers seat.
I get lots of compliments on the light bar from folks at work when they see me pulling out. Not one person has noticed the delay
One the plus side I really like how the amber from the tailgate bar matches the amber from turn signals.
I'm referring to the initial delay. Like I said probably 1/4 second. I believe it's exaggerated or perhaps the opt7 is less of a delay. I'll have to put a stop watch to it when I chance this weekend.I like hearing that last part (about the color). But yes, every video makes it obvious...but I’m referring to the initial delay when you first turn on a turn signal, not the ongoing (and nearly unnoticeable) delay.
What’s noticeable is that the tail lights flash once before the bar activates and “catches up”, at least in the videos I’ve seen. In every other function, it looks great.I'm referring to the initial delay. Like I said probably 1/4 second. I believe it's exaggerated or perhaps the opt7 is less of a delay. I'll have to put a stop watch to it when I chance this weekend.
Yep, that's what gets me. You have one flash before the light bar starts going with it.What’s noticeable is that the tail lights flash once before the bar activates and “catches up”, at least in the videos I’ve seen. In every other function, it looks great.
Was it easy to do? Any “gotchas”?I am running a Putco and wired directly into the brake light instead of the tow hitch, and have no delay at all. Mine is always synchronized. It would have been delayed to the tow hitch plug, but the delay disappeared when I went to brake lights.
Honestly a fair bit of gotchas... a decent bit of minimal voltage wires that would seem correct but ultimately not be, however if you take some time and have ok electrical skills its very doable. It took a few hours to get everything set up. 1 thing to mention however is I was unable to get the brake light function to work based on the signal coming out. Hard to explain, but I was able to get the turn signals, running lights, and backup light working all without delay.Was it easy to do? Any “gotchas”?
Appreciate the response, Sir. I mounted my Putco 60" last week. All of the posts on the forum really helped.Hey sorry for the delay. Yes, I used 1/2" spaces on each side of the camera wiring and 1/4" on the ends. Worked great! I just screwed through the black plastic piece to mount the putco brackets
You're tailgate when you open it clears the lightbar right? When I open mine it almost touches the center of those 2 humps on either end of the plastic. I think I'm going to mount mine where you have. I thought originally I would have to cut out those plastic humps.Did not hard wire so I have a one blink delay on turn signals and hazards. Thought it would bother me, but haven't thought once about it since installing. Here's a close up of the install for orientation/spacing on bumper if anyone is needing.
Quick question... And I have a guess... Do you have factory LED tail lights? I'm guessing that the brake lights may have been a voltage tied into parking? Guessing some sort of voltage mux? and did you try to get brake signal from the trailer harness alone, and rest at tail lights?Honestly a fair bit of gotchas... a decent bit of minimal voltage wires that would seem correct but ultimately not be, however if you take some time and have ok electrical skills its very doable. It took a few hours to get everything set up. 1 thing to mention however is I was unable to get the brake light function to work based on the signal coming out. Hard to explain, but I was able to get the turn signals, running lights, and backup light working all without delay.
I do have factory LED tail lights. I can't honestly remember the exact issue, but it had something to do with the putco bar signal converter. It wasn't just a brake wire, 2 turn wires, a running wire, and backup wire. Instead it had an inline converter that was taking signal and telling it what to do, and when i tried to tap into the brake wire at either the trailer harness or the tail lamps (tried both sides) then the voltage wasn't being converted right or the signal wire was being used for multiple purposes. I wish I could remember more of the exact problem, it was just one of those long nights where I was happy at the end that any of it worked!Quick question... And I have a guess... Do you have factory LED tail lights? I'm guessing that the brake lights may have been a voltage tied into parking? Guessing some sort of voltage mux? and did you try to get brake signal from the trailer harness alone, and rest at tail lights?
my plan was to try and get the signals from the tail lights.. I see most of the wires go by the left side (driver side) wanted to make a harness to plug into. (take four pin and attach to truck, allowing it to be removed. adding for white reverse lights too) But, I was going to try that with the Putco 60"
Yes... everything clears. It's really close. I can take up close pictures of different areas if you'd like.You're tailgate when you open it clears the lightbar right? When I open mine it almost touches the center of those 2 humps on either end of the plastic. I think I'm going to mount mine where you have. I thought originally I would have to cut out those plastic humps.
Should be no different than 19-20. No change in design in bodyHas anyone put a LED set of lights like this on a 2021 yet? When looking at my 2021 the distance between the bottom of the tailgate and the bumper is under an inch it seems. The two bumps/bulges on each end and the backup camera connection seems to be in the way of installing something like this.
Have you done it and can you upload a close up photo of the camera wiring and the ends, I am thinking maybe just the 48" would work better. But for sure need some additional back up lighting for backing into my driveway.Should be no different than 19-20. No change in design in body
look back a few pages. I have the Putco dual LED bar on my 2019. used a Curtis 5 pin trailer harness, and just zip tied everything behind the bumperHave you done it and can you upload a close up photo of the camera wiring and the ends, I am thinking maybe just the 48" would work better. But for sure need some additional back up lighting for backing into my driveway.
I may have missed this, but what light strip is this?Heres a better Video
Mine are not perfectly spaced, but close enough. I have the clamps/clips 5-6" from each end, and then about 15" in from those.
View attachment 58792 View attachment 58791 View attachment 58790
Heres what Mine looks like. If this was going to be long term, I would swap out the end, but since I plan on making an actual harness, this works for now.
Here is how I screwed mine in. Was also going to use loctite, but forgot to apply it. If any nuts come loose, Ill go through and add loctite
