According AMP's installation video on below page, the extender can be easily removed, just line up with about 45 degree angle, then pull off from the clip.Hey folks - question for those with bed extenders: once installed, can you remove the extender? If I was hauling stone in the bed, or something else and didn't want the extender in while doing so, is there a means to easily remove it? As of now, probably going to go with the AMP research, but curious if it can be removed.
BedXtender HD Max - Extend Your Truck Bed (up to 2 ft!) - AMP Research
![www.amp-research.com](/community/proxy.php?image=https%3A%2F%2Fwww.amp-research.com%2Fimages%2Fsite%2Ficons%2Fwebicon.png&hash=0fe93d313b7d868c3e0bbeb6bf261493&return_error=1)
