Tuner on 5.7
What progammer are yall running on the 5.7 hemi. I have a afe cold air an a pedal commander so far. But now looking into a tuner
David525
I’m also running the diablosport t2. The canned tunes are good but for the best results get a custom tune. I went with hemifever tuning for my custom tune.
Ryancassidy
Is there any info on estimate power increase or MPG changes?
As well, new to this tuner, does it have to stay plugged in to be used while driving? Looks like it mounts somewhere and I like the OBD2 tunes instead of the piggyback type of tunes personally.
David525
As far as power increase I can not tell you how much, it will depend on what tune you run and if any other mods are done. Mpg I did notice about 1 to 1-1/2 mpg increase once I stopped mashing the pedal to the floor and started driving normal. The tuner does not need to stay plugged in. Once the tune is in the PCM it’s there until you manually program it to a different tune or back to the stock tune.
Ryancassidy
Thanks for the above. Make sense... seems to work like the other handhelds I've used. I just find it interesting that they dont give numbers for their tunes like other tuners to. However realistic or unrealistic they are :)
fire_mike
These trucks need to have an unlocked PCM in order to tune, right? I’d love to tune mine, but I’m not sure I want to eff up the warranty by messing with the PCM.
Mopar_maxi
You need an unlocked PCM, bypass module and a diablosport t2 or i3.
I bought an unlocked PCM (kept my stock one), bypass module and diablo i3 directly from diablosport. Installed everything and then had Jay Greene do a custom pcm/tcm tune for me.
The truck is much more responsive, better gas mileage and the trans shifts ATON better.
Mtbgordon
Does the security bypass have to remain in even after you complete the PCM swap?
Nails
San Antonio
No it’s just for programming. If truck doesn’t recognize tool that plugged in it won’t let you through
Joekid
NY
Does it eliminate the top speed Limiter ? My Ram cuts off at 110 or 114 mph
Joekid
NY
FishOn
Edge Pulsar is plug and play, no PCM swap/flash. They claim 30HP/30ft lbs of torque on 93... All I know is it's freaking FUN to blast around in Performance mode. Makes a huge difference with the 93 also. Then when the wife wants to drive it, you can toggle through the modes with the cruise control buttons back to stock.
Nails
San Antonio
Are you referring to just a can tune from diablo. Or that you have that already, just not a custom tune?
Either way, if your ecm is stock. Your speedo is off due to tires/wheels.
Answer is yes, diablo only or custom tune will remove it. after some mods/tuning/traction 110 is there in no time.
AmericanRebelution
Western PA
Being able to switch through the modes with the steering wheel controls while driving is pretty neat. I've never had another tuner with this ability.
Nails
San Antonio
Only thing about pulsar is the inconsistency of it. At least from last 2 years, idk if it was a 2019 model thing. Seemed more had issue then not. For the right price, I wouldn’t mind trying it just to get me by. Peeps that have it with no issues say it’s solid and night and day on 93.
AmericanRebelution
Western PA
Picked up my Pulsar here used from a member who had it for 19,000 trouble-free miles. @FishOn gave me some advice too as I was concerned about actual performance gains and reliability. To me, a used one was worth the gamble. Since I was already running an intake, TB, and a throttle controller, I wouldn't call it a "night and day" difference in my case. But it's noticeable in the shift points and throttle response. I actually had to turn down my throttle controller quite a bit.
