speedracernc
- Nov 13, 2019
I have the same problem. Took the truck to firestone and had a lifetime alignement done. The wear did not improve one bit. I ended up flipping the tires on the rim to get more life out of them. Even after flipping on the rim I can see that the edge on both fronts is wearing quickly. I also have never had a tire issue like this before.
Does anyone know if it is the toe that is causing this or camber. If its camber could just dial in a little negative camber to fix the problem.
