VaderRebel
Still waiting for @Nails to say Yay or Nay... to be determined.Vader if it work please lets me know i want to do it for my truck too
Good things come to those who wait@VaderRebel — much apologies sir. Not to fill with excuses, it’s been busy time in work and family time as of late. I have not forgotten or blown it off.
Good things come to those who wait![]()
Wow, the "Kill traction control" and "DRL position" are pretty much worth it to me... gonna do some more reading.Have you looked at the Tazer DT? You can use it to change DRL location, fog light drop out and all sorts of other stuff. Downside is $329
https://zautomotive.com/product/tazer-dt/
Turn the DRL off in uconnect the accent lights are not effected by the DRL mode and will still be lit even with DRL off. The top and bottom accent lights are not bright enough to be considered DRLs and therefore the DRL can't be turned off in Canada I'm guessing they are a requirement.Hi Guys,
I am trying to figure this out, for the USA. If I turn on the DRL in the uConnect, the whole light comes on (I think at a lower output). Are we able to run just the top and bottom LEDs of the headlights? I thought taking the headlights off "auto" and putting on the "parking lights" might do it but I cant see it working during the day. Might work but I just cant see because I am driving but when I am behind a car it looks like all my lights are off in the reflection of their bumper. Thoughts?
DRL is off in uConnect. Do I need to have the "parking lights" on or would it still show in "auto" mode?Turn the DRL off in uconnect the accent lights are not effected by the DRL mode and will still be lit even with DRL off. The top and bottom accent lights are not bright enough to be considered DRLs and therefore the DRL can't be turned off in Canada I'm guessing they are a requirement.
Any word on making the top and bottom strips of white LED brighter? Can't come up with any info on that.You can turn off DRL's in the UConnect settings and that will turn off the low-output headlights as DRL's. You will still have the upper and lower LED strips whenever the truck is running.
A few folks are looking at how to make those brighter so they can be standalone DRL's.
I'm going to contact the Tazer DT folks and see if it's compatible with Canadian trucks.
Tazer or alpha OBD will let you make anything your DRL alone or in combination, or none at all. Low beam, high beam at % power, white LED halo, Amber turn signals, fog lamps. your choice. uconnect just lets you turn off the headlights. halos are always on, but drop with signal activation. you can also choose wih tazer or alpha to not drop, except if you use amber.
Yes, buy with confidence, excellent product and amazing customer support! They are available 7 days a week via text message for support calls! Best mod for a modern Ram, next to a throttle controller in my humble opinion!Hey did you happen to find out if it’ll work with Canadian trucks?
