Hi guys, does anyone who is running a 20x10 in a -18 or -25 have any rubbing? I am deciding whether to go with a 20x10 et -18 or 20x9 et 1.
I have 22x10 -25 with a hint of rubbing at full luck on the reverse up an incline.
Some trimming will eliminate it. It's only happened twice in 4 weeks. I'm on 305-45-22
So Tire size will determine if you rub or not.
Can either of you share pics? I will be running a 305/55/20 for the time being and don’t really want to go bigger.
Nothing is worse than a truck with undersized tires with negative offsets lol.
So now that you've been driving on that setup with the tires proud of the wheel flares for a while, what's your takeaway regarding dirt/spray onto the body?
Sorry for the criminally late response. I had zero issues with rock chips along the side of the truck. Mud and water will absolutely spray up the side of the truck though. Lived in Washington state when I had that particular truck, and I died a little inside everytime it would rain the day after a wash.So now that you've been driving on that setup with the tires proud of the wheel flares for a while, what's your takeaway regarding dirt/spray onto the body?
Issues with stone chips, etc?
Sent from my KB2005 using Tapatalk
Awesome. I ended up going wider with 22x12 and 305/45 hahaThanks. I ended up with factory 22's and OE sized (285/45/22) Continental Terrain Contact AT's.
I'm very happy with the setup.
