U
User_21361
Guest
TDLR: The Clayton offroad 2.5 lift springs DO fit a 2020 Rebel
What I tried to accomplish: I recently added Fox 2.5 shocks in the front and rear. The ORP/Rebel shocks give 1" in the back, but the Fox coilovers allow for me to go to 3" inches in the front. This means I needed an extra inch in the rear. Also, the rear shocks are OK for 0-2" of lift.
What I got: The shocks fit beautifully. The ride on street is great (and wife approved)!
Measurements:
Spring Comparison.
The springs:
www.claytonoffroad.com
The install: The process was exceptionally smooth. The drivers side was significantly more challenging than the passenger side. I think this was due to a few factors. First, I started on the drivers side which meant I was learning as I went. Second, Since the springs were an extra 1.5" longer than stock, getting the axle down that far was challenging. After disconnecting the sway bar, I started to hit what I thought was a mount. I later realized after a lot of stress, that It was actually hitting the skid plate. I took out one bolt on the skid plate and wedged a small piece of wood in there to lower it and I was off to the races.
Pro tip: To push the rotor down and get the spring seated, I used my forearm for pressure while pushing the spring. This hurt like hell. I decided to put a set of knee pads I use for home projects around my elbows/forearms and use them to push. It worked like a charm and saved my forearms.
Only potential issue: The lift was a little more than I hoped for. Now I have about 1.5" higher than my stock rebel or 2.5" over a stock, non rebel. My concern is for my new shocks. Does anyone have input on if pushing them past the 2" range will damage them in the long run? I plan to call Fox on Monday to A) see if I can get a longer shaft or B) run them without concern. I don't plan to adjust the fronts until I figure out if the rear is ok.
Measurements:
Spring Comparison.
The springs:
Jeep Gladiator 2.5" Triple Rate Rear Coil Springs 2020+, JT
Jeep Gladiator JT 2020+ triple rate coils provide the perfect balance between on and offroad handling, ride quality, offroad flex and weight carrying ability. Triple Rate Free Length = 21.500" +/-.25 Spring Rate 1 = 159 lbs/in Spring Rate 2 = 280 lbs/in Spring Rate 3 = 360 lbs/in Powder Coated...
