Finn5033
MN
Technical it was yesterday but installed OEM LED headlights
Finn5033
MN
They look Great!! :cool:
Good Job.. (y)
Thanks, I actually ordered the alpharex pro’s, they sat in my garage for a month and ultimately decided to return them. Then I ordered the full Lasfit LED package to install and a couple days later I came across a member here selling their OEM LED lights that they took off after only 600 miles so I pulled the trigger.
RAM Patriot
Clayton GA
I went the Alpharex route as well, but if I could have got the OEM LED's under $1,000 I probably would have gone that route as well to stay all Mopar.
I did go with the Mopar LED for the taillights. They were plug & play.
iLikeTurtles
That's the one I have which causes the key fob not detected issue. It seems to be hit or miss if you get it. Good luck.
I have not heard of thise issue, is there a link or video to it? I will return them if that is an issue.
iLikeTurtles
Found this regarding LASfit CHMSL...
Will be returning before i even install them. Not worth the hassle of a work around for a $30 dollar part on an almost $70k truck... seems to be an apparent issue that the vendor should note on the website.
NightRAM
Installed the Magnaflow catback exhaust, #19430, this weekend on my Laramie Night Edition. The sound is exactly what I was looking for. Louder than stock, no drone and roars when you punch it. I have had this truck 2 months now and I love it!!!
iLikeTurtles
Can you post a video of it?
I ordered 19429. I plan ti use the Niosh app for before and after of various points to grasp volume difference
Timeless
SC
Any noticeable change when MDS kicks in? Thanks.
jakemyster84
I installed the bed rail kit into my Limited, had a bit of trouble getting in the inserts into the holes due to the spray-in bedliner. Took a small file and filed down the liner a bit and was able to tap in the insert fairly easy.
Sir Ramcelot
Same one I have...love it!
