12” radio help
jlorenzo2010
Buying a 12” radio with module from a junk yard what else will I need to swap my 8.4 radio? New to this forum thanks in advance
Nothing if you have 8.4 NAV.
If you have Non-Nav you'll need LVDS cable.
if needed:
That is it? Any radio codes or extra programming needed? I was looking in YouTube videos amd I am just a little confuse. Thanks for the input.
I thought you were asking about hardware, And you basically has everything you need, That's why i said nothing lol. It definitely needs a little more than that.
You will need to Repin a connector, Get the radio code and program the BCM to the new module.
Not as hard as you think, you just need to know what you're doing.
Follow this tread for all the info you need:
Thank you for all the information. If the radio is already out how can I get the radio code(radio serial number or VIN number)?
Serial number.
You can also get the code by the vin from the dealership.
Bro I got one n is costly about $400 more. You have to match vin number to the redio about $250 at dealer. Then buy a programmer to bypass module $100,wirreherness $260. If I would of known what I know now
Anyone have a part number for the UAX radio module? Mine is dead. The stealer says if I was the 1st owner I'd be getting a new one free. I need to find a used one.
Just get the same part number of your dead UAX module.
