Please do not hesitate to follow up with our Canadian Customer Care team for further support while working with your dealer. You may either call 1-800-361-3700 or submit your info at https://forms.chryslercanada.ca/contact/en/contactCCI.php?brand=dodge to receive an email follow up.Noticed this after getting back from a 3500km trip. Didn’t have anything hit the truck other than some heavy rain and wind. Back to the dealer I go.
I feel your pain, my back bumper is doing that on the top edge. I need to take it in and have it looked at
I have the same problem on my rear passenger. Noticed it at like 2,500 miles.
Hi all, please feel free to send our team here a private message if you address this with your dealers and would be interested in any additional support for that process. We are more than willing to escalate cases on your behalf.One of mine is the same, because it’s a small plastic part, likely to do it again, I’ve been like MEH
Oh wow I did not know that. How do u swap it out. I heard u have to take handle off to get to stationary block tht I’m having paint issue with to swap it outIt's a $7 part.........
I hope they replace it for you but if they give you some trouble... it's a very cheap fix. Takes 2 minutes to swap too.
Open the door and you'll see a rubber cap leveled with the handle. You unscrew the screw(sorry, don't remember the torx size) while pulling on the door lock until it comes out, That's it!Oh wow I did not know that. How do u swap it out. I heard u have to take handle off to get to stationary block tht I’m having paint issue with to swap it out
There ya go:I was in for an oil change on Tuesday and showed them this. Not sure how it would have happened, but they said I would have to fix it. There is literally no paint on that section on the bottom of the key hole.
Thanks. I will hang on to this part number.There ya go:
Non-proximity, Painted Billet Silver, Left.
Part # 6FX82JSCAC
2020 Ram 1500 Big Horn Crew Cab 5.7L Hemi V8 4WD Cap. Door handle. Left. Color: [light gray - 6FX82JSCAC | Factory Chrysler Parts, Bartow FL
Cap. Door handle. Left. Color: [light gray/blue] exterior: [billet silver metallic clear coat]. 2020 Ram 1500 Big Horn Crew Cab 5.7L Hemi V8 4WD. Genuine Ram Part - 6FX82JSCAC (6FX82JSCAA, 6FX82JSCAB). Ships from Factory Chrysler Parts, Bartow FLwww.factorychryslerparts.com
You said it takes 2 minutes to swap out. Can u tell me how to change itIt's a $7 part.........
You open the door and on the inside of it, at the same height of the handle, you will find a rubber/plastic cap.You said it takes 2 minutes to swap out. Can u tell me how to change it
