TrailBoss
The wait far as getting the lift suck but was well worth it.  Like the ride so far.  Only had one small issue but was able to correct it.  The passenger side coil over bracket was in the wrong direction but was able to spin the coil over 180 which I reached out to several people before trying.  The only modifications needed to be done was on the rear shock mount you have to grind down some on the bottom mount for clearance of the shock body and also cut out some of the front wheel well plastic for clearance for the reservoirs.  Rear springs I didn't mark before pulling so hopefully they are in correct spots.  Still not sure on that part or if it matters.  Netted a lil over 3" in the front at the current setting it came with after it finally settled and then a little over 1.5" in the rear.  Was hoping for a little more lift in the rear, but so far I am very happy with the kit.  Only downfall was it took me 2 days to install which I guess is not too bad with doing it in the driveway by myself with fiancé fetching tools and beverages!  Only thing left now is to retorque everything after driving it some.
