vincentw56
- Aug 5, 2020
I bought one of of eBay.Do you have a link to the center console ark rest? Ver interested.
I have been considering something similar but somehow using the space behind the wheel wells on each side for a single. They should fit under the tonneau. Just need to fabricate something. Looks great.Installed DIY Jerry can mount. View attachment 68434
I have had my lomax cover for many months now and have been very happy with it.Ordered a new Lomax tonneau cover and a bedrug liner. I'll probably get it installed this weekend, provided it shows up by then.
Thanks. I thought of the wheel well location also. I can unbolt them from the cross bar and connect directly to the cargo rail, just have to decide what two cans to bring with me.I have been considering something similar but somehow using the space behind the wheel wells on each side for a single. They should fit under the tonneau. Just need to fabricate something. Looks great.
Seems to be the general consensus for them.I have had my lomax cover for many months now and have been very happy with it.
What did you use to connect to the side rails? I want to DIY a few things (bike bar for example) to use that rail.Installed DIY Jerry can mount. View attachment 68434
I had some 22mm T-nuts with 12mm thread floating around that worked, they are a smidgen small but OK. The closest that I found in SAE was 9/16 with 1/2-13 thread from https://www.mcmaster.com/machine-table-t-slot-nuts/ I tried unsuccessfully to add one to my pending order to do a fit check, their shipping is fast but furiou$$$ so maybe on my next order.What did you use to connect to the side rails? I want to DIY a few things (bike bar for example) to use that rail.
Looks great!! How are you liking the rough country lift?Last week I added a 6 inch Rough Country lift, 22 inch Fuel Offroad Blitz Rims with 37 inch Nitto Ridge Grapplers, and a Borla ATAK exhaust.
View attachment 68002 View attachment 68003 View attachment 68004 View attachment 68005
Looks great, how much weight you end up pulling? Also, where did you get the red overlays for the hood?Did a dry run of hooking up the trailer I will be pulling Friday for a house move, and getting the WDH and the aftermarket electronic brake controller dialed in. I might be biased, but they look good together. I will definitely be adjusting the links once the trailer is loaded.
View attachment 68013 View attachment 68014 View attachment 68015
Thanks! I never made it to a scale, but if I had to guess, I was pushing 7k to 8k lbs with trailer and cargo. I got my red hood decals off eBay.Looks great, how much weight you end up pulling? Also, where did you get the red overlays for the hood?
Those are some bad-A$$ DRLs! VERY nice!!!Had the day off work. Decided to not be lazy and mounted my lights. Still need to wire them up.
My new running boards come in today as well. Should get those on today as well.
Installed door sill protection. They fit well and were pretty easy to apply accurately and without bubbles. The texture is similar to bed liner, not rough/scratchy like sandpaper I think it works well on a dark color, but might look strange on light colors?
I'm happy for $33.
Amazon.com: Red Hound Auto Door Entry Guard Scratch Shield Compatible with Ram 1500 2500 3500 2019-2020 Crew Cab 4 Door 6pc Custom Fit Door Sill Scuff Paint Protector: Automotive
Buy Red Hound Auto Door Entry Guard Scratch Shield Compatible with Ram 1500 2500 3500 2019-2020 Crew Cab 4 Door 6pc Custom Fit Door Sill Scuff Paint Protector: Door Entry Guard - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Took off the ram running boards (they were chrome). And yes those are method wheels and a leveling kit eagerly awaiting for the tires to arrive next week.
Nice! I really lile this! This'll be good prevention from my daughter slipping as shes getting on.
Nice! Which Method wheels?
