I like that seal even better than the 1 inch one I got. I’m going to order that.Finally got rid of that terrible Mopar soft tri-fold and got some silver rails and BakFlip. A little water gets in, but some silicon on the ends of the rails seems to stop that when parked on a hill (they should really cap the ends by the tailgates off.
FYI... I know it looks somewhat mis-aligned. I fixed that after the pic.
Since I probably will get the questions, I used this to seal the tailgate up on the top. It is much better than the TruxSeal for these Rambox/MFT issues. You can see it on the top right of the pic. https://www.amazon.com/gp/product/B07147Y43J/ref=ppx_yo_dt_b_asin_title_o09_s01?ie=UTF8&psc=1
can you share some pictures of where you installed the sealsFinally got rid of that terrible Mopar soft tri-fold and got some silver rails and BakFlip. A little water gets in, but some silicon on the ends of the rails seems to stop that when parked on a hill (they should really cap the ends by the tailgates off.
THANKS for the info Heminator! NOW my Bed Extender will actually be an Extender and not simply a Divider!Installed the RamBox Handle and Grommet Kit (for 2019/2020 DT Ram 1500s with RamBox) for my RamBox divider/extender to be able to be used as an extenderI got a good deal on eBay and it shipped pretty quick (had it 3 days after I purchased). Link is below if anyone is interested and they still have 3 left (sold 43).
Pardon Our Interruption...
www.ebay.com
View attachment 67861View attachment 67862View attachment 67863
It may be an optical illusion but to me the truck seems to be sitting too low like it needs the hitch dropped another hole or so. Did you do the pre connection measurements and then adjust the hitch? If your not going far or fast it may not matter much.Did a dry run of hooking up the trailer I will be pulling Friday for a house move, and getting the WDH and the aftermarket electronic brake controller dialed in. I might be biased, but they look good together. I will definitely be adjusting the links once the trailer is loaded.
It is not an illusion. The truck is sagging a bit. I borrowed this WDH from my neighbor, and I was trying to do as little adjustment as possible. It is an in-town move at low speeds, so I am not for sure if it's worth adjusting. I would like to see it's sitting level though. Just don't know much about these hitches.It may be an optical illusion but to me the truck seems to be sitting too low like it needs the hitch dropped another hole or so. Did you do the pre connection measurements and then adjust the hitch? If your not going far or fast it may not matter much.
Sounds like a trailer wiring issue. If trailer is brand new, I'd be taking it back to place you got it fromForgot to mention this in my earlier post. This blew when I hooked up the brand new trailer to the truck this morning. Trying to figure out why. Initial hookup yielded left side front and rear marker lights working. Never could get the right side to light up only in the rear. After going through all the light checks and inspecting the inside of the trailer, all while still hooked up to the truck, closed trailer and all marker lights no longer worked. Checked power to my TBC and everything showed still connected. Never lost lights on the truck, just the trailer. Used the spare fuse in the engine bay box and original lights returned. Still no right rear marker light. Brakes and turn signals never stopped working. Sounds like a short in the trailer wiring, but it's brand new? Never had an issue with other trailers. Thoughts?
I'll try to remember to take some pics tomorrow.can you share some pictures of where you installed the seals
I don't understand why everyone hates on the stock tonneau. I actually really like mine. I get that it may not be as secure as some options, but it is far from terrible.
