Occasional rattle in back of cab
gHiDoRa
Elvis Presley
Rear seat, no i didn't record it, it's just like any metal rattle sound and i already tied all the screw, no more noise now.
Yanser
Had an annoying rattle coming from both sides. Turned out to be the seat belt attachment points for the shoulder. There is a piece of metal under the plastic trim that bangs against the sheet metal. Put some adhesive foam behind it and problem is gone! Had to finagle it in through the slot in the trim.
jeffauclair
Rear seatbelt or passenger? I have a rattle in the B pillar/ upper seat belt sliding area and I just can’t locate the rattle as I almost did a accident while trying to look over my shoulder on every bump
Meatshield
My truck has the same rattle. I have found that it is coming from the cab frame body mount. Here is a video that I found that describes the same noise that you are hearing. There is not a fix that I know of at this time. They are on something like the 3rd revision of the body mount but people still report that it is not fixing the problem. I will wait for the TSB on this one.
RamCares
Michigan
When you decide to move forward in addressing this with your Ram dealer, please know that we are a PM away and more than willing to escalate a case on your behalf to a specialist who can work alongside you and your dealer.
Mark
RamCares
Cummins3
There is no fix how will you escalate the issue. I have "the new cab mounts" which are suppose to fix issue but they haven't
reamer31
My 2019 Ram Big horn with 8000 miles on it is going in for the 3rd time this Nov 3rd for clunking rear lower cab . Asked them if they would look at rear cab mount from what I'm reading on this page?
Looked like one person had luck this this....anyone have luck with this ????
reamer31
Any luck on getting this fixed? My 2019 Ram 2500 going in next Thursday asked them to look at rear cab mount
jeffauclair
i have tightened all my door pushing the latch further in a little. seems to help a little with cabin rattles. but there’s so much little noise in those truck that i gave up trust in dealer fixing it and myself on finding it. paid for a 80k truck(yeah canada) and should enjoy riding it not trying to fix it. really wish engeneer at ram would care more about those little annoying things than trying to make a better “technology “ truck. my 2 cent
RamCares
Michigan
Hi @Cummins3 - If you are willing to try and address this further with your dealer, I am more than willing to get the appropriate internal resources re-engaged so that we can work toward a true solution in your situation. We are always a PM away.
Hi @reamer31 - If you would be interested in the support of a specialist who can work alongside both you and your dealer while your truck is in service, our team is a private message away and more than willing to assist.
Mark
RamCares
Cummins3
Mark
RamCares
I don't feel like being a guinea pig sorry.. FCA needs to got this resolved and either a TSB or a recall and stop using us as guinea pigs... No thanks I'll wait I don't have time to keep dropping off truck and picking it up
reamer31
Mark
RamCares
I took truck to Dodge dealer in Coldwater Michigan they said there's no fix for this issue at this time. They said they are working on resolving the issue hopefully before I sell the truck.
reamer31
Right you spend that kind of money on a pickup truck you feel it should be a solid truck but sounds like it's going to rattle apart
chase01
Anyone experience A rattle when hitting bumps on the road? Can’t put my finger on it but it sounds like it’s coming from the passenger rear side of the cab. Thought it might have been seat belts but I ruled that out. Any advice?
Yes.. I have it going on in my 2019 Ram 2500 Regular Cab 6.4. its driving me insane. I checked behind the panel where the driver side seatbelt is... FCA used cheap plastic fasteners to hold wiring and everything else in... I corrected that but the rattle still persist. I tightened B pillar cab mounts... Noise stopped for 1 hour and then returned.
chase01
The rattles sound in mine is from these bolt, there is a washer in each bolt so they making really loud noise whenever I'm go over a bump.
Where are these located in the truck?
Fidomac
The attachment of seatbelt to b pillar rattled on my ram.....a bit of self adhesive foam fixed it... don't make it so tight the seatbelt can't swivel
skny
Do you have a rear sliding window? My rattle was coming from the sliding glass being loose in the tracks. I had it replaced and it's all good now.
I’m “hopeful” my rattle is from this. Have had a mild rattle over slow speeds since I bought it. I assumed it was my tri fold tonneau - but I’ve had it removed the last week or so and it’s been louder than ever.
Tonight I tried opening the power test slider - and the sound went away; either that or having the window open just masked the sound. I’ll mention it to the dealer my next visit. Part of me wants to not mention it and wait for the frame around it to crack which seems to be inevitable so that I don’t have to make an extra trip to the dealer 😜
Hrspwr88
I found the exact rattle as you explained. I just noticed my driver side rear seat latch is loose.
Rankinroudy
Yes i had the same thing the push pins are loose too i just used some velcro it stick it to the wall..
thank you for your thread and photos. I had the same rattle on my 22 ram. Velcro solved the problem. Thank you
