Put my Weathertech floor mats in today - not keen that they cover up the Ram Bins in the back, but the front ones fit perfectly.
Also, ordered some tow hooks - and investigating my mud flap options. Any reason not to get Weather Tech mud flaps? The Mopar ones seem problematic, from what I'm reading.
I’ve been using weathertech products for as long as I can remember and love their floor liners. I had the same complaint about covering the bins but it’s proven to not be that big of an issue.
I ordered the weathertech mudflaps and put them on for a dry fit and absolutely hated the look and fit. The design is just off. Unfortunately, they missed the mark on this one and I put them back in the box. I bought the husky mud flaps instead which I really like the look of, they look OEM, and the fit was perfect.
My post on my husky flaps install is #9626 in this thread. Hope this helps with your decision.
Sent from my iPhone using Tapatalk u
Same here - have the weathertech floormats front and back and love them (just lift up to access in floor storage) and had weathertech mud flaps on my 2014 ram but went with husky mud guards on my 2019 based on posts in the forums. The huskies look great and provide good coverage - I attached them with the 3 provided screws to the existing holes in outside of wheel well but did not install the 4th optional screw in the wheel well liner. There is an indent in the liners that prevents use of the provided tape and seemed it would interfere with the 4th screw. I added my own 3m double-sided tape on The edge and held them together to adhere - not sure if it will stick or in needed.
You doing the install yourself or at a shop? If at a shop what did they quote you?
I actually watched a YouTube video lol it didn’t look horrible. But I’m not much of a mechanic so I’d rather not eff it up, so I’m having a local guy do it. Right around 350 with tax, that includes an alignment as well
Is your goal to level/remove the rake?
LED bed lights on a magnetic switch so they turn on when tailgate opens. Manual switch to turn off if desired. Powered off battery so not igniting dependant. Only took me forever and a day. Never wired anything before but it was pretty straight forward.
Replaced the 3rd break lights with LED
Before
Assembly
Bulb comparison
Comparison
LED installed!
In the dark
$15 canadian bucks on amazon - https://www.amazon.ca/dp/B07JY9Q49M/ref=cm_sw_r_cp_api_i_I7lrFbXDBGA41
  • Back
