NorthernArea51
NY
Did Mad Max order this? (Not saying my eye brows didn’t raise in appreciation)
I’ll be honest...I’d love to see Ram do some color options that similar to the Tacoma’s. This seems like a close comparison
5thGenRebel_AMK
PA
One of my favorite mods.... stickers
also put this on:
and finally installed some PPF along where the rear quarter panel meets my tailgate. The bottom of the tailgate rubs ever so slightly when closing and opening it. Rubbed a little bit of paint off the gate, glad I caught it to hopefully prevent more damage
NorthernArea51
NY
also put this on:
What size is that sticker? And where did it come from? ;)
ny2az
Scottsdale, Arizona
Recently I installed the Sprint Booster in my Rebel Review, love what it does! Makes my rebel anxious to move, barely touch the pedal and the throttle opens (some people may not like this, but I do). I also like that once you set it to the setting you like you can remove the controller so everything looks clean (I keep controller in my glove box for whenever I need it. i.e. snow or mud). I also installed vitesse throttle controller on my wife's Durango...review not so good! It comes with a ton of bulky wires and the controller is not removable (most throttle booster controllers are not removable) so it was pretty ugly. But the big downfall was it set the Durango into limp mode after 2 days of driving...Took it out, reset the ECM and threw that one in the trash!
Sry to hear you weren't happy with the Vitesse controller ... l have the Vitesse controller installed in my 2020 Limited and have not experience one negative issue with it... l am completely happy with it ... l'm sure it functions as the sprint booster and the pedal commander does and that you will hear from members here that at one time or another all of these controllers had experienced issues for one reason or another ....
Duran
Going to add some vinyl horsepower to my truck tonight! Gotta get my name out there if I want to be one of the cool kids.
Be careful bro thats 20 hp your working with right there
5thGenRebel_AMK
PA
it's 1.8x3 inches. I like it a lot, had one on my 4th gen for a while and held up great
Edwards
TX
also put this on:
You might check out this thread on your tailgate. If it's the same issue, you can fix it permanently with a rubber washer.
5thGenRebel_AMK
PA
thank you, i've actually read this and did this mod. it worked well in preventing the top of the tailgate from rubbing when its closed, but the bottom of the tailgate still rubs the rear quarter under the brake light when the tailgate is in the down position. theres so much play in these tailgates...
z0n3
also put this on:
Where did you get the cap from?
Taillight and side mirror tint
Waterfowler41
Chicago
Since I lost my cell phone mounts when I installed the Trigger switches had to add a new mount from ProClip. Been a while since I had a ProClip mount, use to use these a lot back in the good ol’ days when we needed external XM radio receivers.
You mean like the Destroyer Gray in the Built to Serve models?
