Has anyone setup a "roof top" tent such as the Ikamper? if so what did you need to purchase it to set it up and do you have any pictures or issues?
If you look at my post at the bottom of page 525 you'll see my rig with a Tepui Autana 4 person roof top tent, measures 4ft x 6ft when its folded up for transport and 6ft x 8ft when deployed, its sitting on a KB Voodoo MAX Modular Steel Max 18'' frame works extremely well and holds 700lbs static can take it on and off very quickly with only 4 bolts.
Link for the Bed Rack - https://www.max-modular.com/shop-max-modular/steel-max-18-high-truck-bed-rack
Could it be that you have amber wired up to work as brake and turn and that might be the issue. How about if you just left the ambers as turn signals and no break light and white wire for the white courtesy lights?
The brake light and turn signal light are the same wire on the harness. Yellow for left turn driver side and green for right turn passenger side. The only other wire is the headlight/running light Brown wire
Dropped my 2019 Ram 1500 Bighorn at the body shop to repair a dent, gash in the paint, and broken bed rail cap...all self-induced while moving a ping pong table I was selling. Not a good return on investment!
Ouch! If it makes you feel any better 3 days after I bought my 2016 Gen4 Big Horn I caught the corner of a trailer with my front fender in my shop. That required a replacement fender and repainting my driver’s side door all before the first payment.
I hope that ping pong table sold for around 2k.
Well they got an $800 ping pong table for $150!
I feel for you! I have pretty bad luck denting up my trucks and I can’t stand looking at them so they instantly go to the body shop as well. I “joke” with my body shop guy regularly that I put his kid through college.
Got a red Hemi decal to match the red tow hooks. I just wanna get some bigger tires and I’m done with the mods it’s been a crazy and expensive 7 months lol
I have LASFIT LEDs inside and out and have not experienced any problems. How would I know if my LEDs are causing this RF noise you are speaking of?
If your LEDs are not causing you any issues then I'd consider there to be no issue. It's technically guaranteed that everything electrical causes some RF emissions - look at any of your personal electronics and read the FCC Class B warning. BUT if they emit such a low amount that it does not cause anything else to go wonky you're good to go, or as good as can be expected.
Those amber lights in the grill are niiiiice . What are they???
NM - found them.
Thanks to Skater for turning me onto this. I already got comments on it from my passengers.
Put on my wheel set up to tie my build together!
Bilsteins all around on the 5th setting
Mopar UCAs
20x9 Fuel Vapor Matte Black +1 offset
Continental TerrainContact A/T tire
275/65r20 (34.1” x 10.8”)
No trimming or rubbing
Tires are incredible. Road noise on par, possibly better than stock. Comfort on par with stock as well.
  • 1791
