Brake Pedal Noise
Biga
Cincinnati
I noticed a slight noise when I hit the brake pedal the last few days. I looked at pedal assembly and I can move the pedal left to right maybe a quarter inch. Is this normal?
Not normal. Get under and take a look. Maybe it’s loose (pedal bracket) and worked it way even more loose by applying the brakes. I’ve seen this done.
Rare, but happens if not tightened from the factory
Hello,
I have the same issue. Is this something that can easily be addressed at home with some tools, or should it be brought to the dealer and claim warranty repairs?
I used some white lithium greese on the linkage and is has quieted somewhat but still a little noise.
I had a noise as well and the dealer had to add grease and the noise is gone.
Hello guys... do you know where to add grease to quiet the noise?
