Brake Pedal Noise
Biga
Cincinnati
I noticed a slight noise when I hit the brake pedal the last few days. I looked at pedal assembly and I can move the pedal left to right maybe a quarter inch. Is this normal?
768mph
Not normal. Get under and take a look. Maybe it’s loose (pedal bracket) and worked it way even more loose by applying the brakes. I’ve seen this done.
Rare, but happens if not tightened from the factory
Alendore
Hello,
I have the same issue. Is this something that can easily be addressed at home with some tools, or should it be brought to the dealer and claim warranty repairs?
Biga
Cincinnati
I used some white lithium greese on the linkage and is has quieted somewhat but still a little noise.
Douglas31
I had a noise as well and the dealer had to add grease and the noise is gone.
James Cole
Hello guys... do you know where to add grease to quiet the noise?
