i put a k&n intake on my 2019 ram big horn i dont have numbers but i do feel more power better acceleration and a nice rumble. my next upgrades probably long tubes borla atak exhaust and a diablo tuner when i put them ill comment my exoerienceI’m sure this has been discussed. But what did everyone do for exhaust to see real number gains? Headers? Y pipes? Resonator delete? I think I wanna do a borla S type or atak.
which cam do you recomend? is there a certain brand?Cam will give you biggest gains. And a tuner. Intake, long tubes. I used an x pipe and truck loved it. Heads will help after all this other stuff is done.
There are a few guys who will grind you a cam. Modern muscle, Greene performance, Texas performance. And I’m sure the list is long. You can talk to these guys and see what they recommend for the type of performance you are looking for. There are different grinds for different purposes and mods and things like that. These forums are full of different guys mods and cams they got. Best to search and see what you can read. Cause there is a lot of info on here.which cam do you recomend? is there a certain brand?
What did the ram airflow run you?I added the B2 Fabrications (Moderate) Magnaflow Performance Exhaust. Sounds great but did not realize any performance gains.
I have noticed huge improvement in Performance / Power / Throttle Response from the RAM Airflow however.
At least 30 HP Gain in my opinion, but I do not have a dyno to prove it.
Cheapest I seen was $800How much was the ram airflow?
I paid just over $900 at my local dealer but I saw it cheaper on Bam Wholesale.What did the ram airflow run you?
Looks like the ram flow sucks air from the upper radiator area which passes through the a/c condenser first... hardly even a "cold air" intake.
